Hi Damian, here is the Debug Info:
Audirvana 3.5.45
SW volume control: ON
AUTO: C:\Users\Amit\Music
Library database path: C:\Users\Amit\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1194MB
Local Audio Engine:WASAPI
Speakers (iFi (by AMR) HD USB Audio)
Model UID:Speakers (iFi (by AMR) HD USB Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9ae4e340-b23d-49cf-97a9-40823b749783}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e0f3cd42-fafd-4eb5-ad49-518c281e8c2c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e0f3cd42-fafd-4eb5-ad49-518c281e8c2c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
