I downloaded the android app. Works fine on my phone - reconnects seamlessly. On my android tablet it is very hard to connect. If connection lost I have had to reset the app twice and re-enter the six digits to get connected. No use to me as I wanted to use the tablet as the remote.
I found it hard to have both devices connected to as remote app. I use only my iPad and if I try to use the iPhone as well the iPad will drop off. Try using only the tablet
Hello @Hugoman56, which version of Android do you have on your tablet? If its the version 9 of Android then we made an update regarding connection issues last Sunday, did you made the update?
Yes, I tried the new app and working fine now. The only issue now is with the windows app. Often when I select next track the music stops and I have to press play again. I then get initializing audio device then loading first track. Deosn’t do this if playing on laptop speaker.
@Hugoman56 Can you send me a copy of the “Debug Info” while you are connected to your DAC? You can get it in Audirvana Settings>General>Debug Info
Finally got this working. Reinstalled Catalina. Clearly the Catalina upgrade messes with the remote access.
