Audirvana Studio, Bubble UPNP and IFI Zen Stream to Aqua DAC (MacOs)
Hello,
first post for me here, loving the audio quality of this little software!
After installing Bubble UPNP and multiple attempts I managed to get my Ifi Zen Stream recognized as renderer on Bubble UPNP, and finally got audio to my streamer and DAC
Only problem is that I can’t manage to get direct DSD stream to DAC, it seems AS only streams PCM to streamer and to DAC
Zen Stream shows only yellow light, Yellow PCM 176.4/192/352.8/384kHz
My DSD files range from 128 to 512, I’ve tried multiple settings, including limiting DSD to 128 as my DAC can only handle DSD128, and yes also 128DSD are still being converted to PCM
Any reccomendation on what to do to have DSD direct to DAC instead of PCM?
thank you
My chain:
2021 Macbook Pro (M1 MAX)
IFI Zen Stream (trhough WiFi)
Aqua La Voce S3 DAC
Software:
Macos Monterey 12.1
Audirvana Studio 1.8.7
Bubble UPNP 0.9-update42
IFI Zen Stream on latest firmware 2.30.2
Hello,
macOS is not able to send raw DSD streams. That’s why the DSD over PCM standard has been developed: to send raw DSD in a fake PCM stream.
To identify it as such, there are 8 bit markers in it.
And the presence of these markers doubles the need of bandwidth, thus explaining why on a mac only half of the max DSD rate is available.
You should be able to play DSD at least up to DSD256 by selecting DoP 1.1.
Can you dump the debug info here?
Hi Bitracer, here is the debug info
Audirvana Studio 1.8.7 (10807)
macOS Version 12.1 (Build 21C52) with 64GB physical RAM
AUTO: /Users/ale/Documents
iTunes/Music library synchronization: last synchronized on Sat Dec 4 08:57:36 2021
Library database path: /Users/ale/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Preferred device: IFI AUDIO IFI Model UID:iFi audio IFi UID:uuid:188a2caf-c6b7-7fa8-5a9f-d49cdda0f78c
Currently playing to UPnP device at 32 bits 88.2kHz
UPnP device at http://192.168.50.242:49152/description.xml
ID 0x0 IFi
Manufacturer: iFi audio
Model Name:
Model UID: iFi audio IFi
UID: uuid:188a2caf-c6b7-7fa8-5a9f-d49cdda0f78c
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
32 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:07:42
CurrentURI: http://192.168.50.116:49152/audirvana/audio_67.wav
CurrentURIMetadata:
UPnP devices found : 1
Device #0: ID 0x0 IFi UID: uuid:188a2caf-c6b7-7fa8-5a9f-d49cdda0f78c Location: http://192.168.50.242:49152/description.xml
Max. memory for audio buffers: 62464MB
Exclusive access: Disabled
Device #0: ID 0x32 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
Device #1: ID 0x2d JustStream Audio Driver Manufacturer: Electronic Team, Inc. Model UID: JustStreamAudioDriver_ModelUID UID: us.electronic.juststream.audiodriver_v1_0 Model Name: Electronic Team, Inc. JustStream Audio Driver
Set the DSD capability to DoP 1.1 and you should be good to go.
Also reduce the pre-load cache. It’s way too much. Start with 4000MB and work from there if necessary.
can’t find this in settings, using AS 1.8.7
see below
In the settings, output chain → Loading, Decoding, click on the cogged wheel and set the pre-load cache.
hi, yes that I did find, I meant, couldn’t find setting for DoP 1.1 thanks
Output devices, Native DSD streaming method.
hi, if you see my previous screenshot, this option is not shown for me
any clue why?
oddly enough, Audirvana sees ability to handle DSD128, see under output device
Not sure, it could be that the JustStream is interfering somehow. Maybe @Antoine can help you further with this.
What you can try is to select the built in audio device, change the DSD streaming setting and select back the iFi streamer.
Hi Bitracer,
I did uninstall JustStream and selected built-in audio → change to DoP 1.1 → switched back to IFI stream, still not working unfortunately, thank you for your time trying to help!
No worries. You may want to open a ticket with iFi while waiting for other ideas.
Also check the DSD setting on the iFi. Maybe something is wrong there.
I just sent an email to [email protected]; is this what you mean by raising a ticket?
I also checked iFi streamer settings and it’s set as ā€œDSD Playback Mode: DSD over PCM (DoP)ā€
thanks again
By sending a mail to [email protected] you raised a ticket with Audirvana.
I think @bitracer meant to send an email to iFi customer support, because it could likely be a problem with the Zen streamer firmware or a driver provided by iFi. In that case they need to solve the problem (by providing a firmware update for instance).
