Hi GaseousClay,
Are you trying AS or are you not trying it at all, because it does not have a column browser?
Hi GaseousClay,
Iâm away from home, for work, for most of the summer. Iâm disinclined to try AS at all, due to the lack of a simple, UI-integrated solution, for browsing my extensive music library.
The first opportunity I will have to use it, when I will be in front of my computer long enough to learn a new app, will likely be in October, and it doesnât sound like the free trial will be an option then.
As a result, due to all of the above facts, I am unlikely to ever use AS, unless it gets a column browser and free trials are extended to all previous licensees, @Doudou.
Of course, most of this is up to @Antoine. If he wants to sell subscriptions, he can try to build software that appeals to his user base. Iâd use AS in a second, if it simply worked like 3.2.20 with improved sound and slightly better features. Unfortunately, the âbaby and the bath waterâ path that @Antoine has taken, with the last two full updates doesnât really appeal to me.
I told my friend who lend me his A3.5 activation key what you showed to me with your screenshots of the column mode of A3.2.2.
AS claims the processor more than 3.5.
the temperature of the processor rises after a short time, this is not the case with 3.5.
Is your Audirvana still busy analyzing the audio files? If so that explains the CPU usage and the temperature. It went up to about 20-25% on average constantly here on my 8th generation i7 quad core CPU. Now itâs basically idling while playing music now thatâs finally done
eigentlich nicht, es sei denn, es geschieht im Geheimen.
Jâai laissĂ© plusieurs messages pour un support technique et pour tenter de faire prolonger la pĂ©riode dâessai, commencĂ©e top tĂŽt, lâapplication ne fonctionnant pas correctement, mĂȘme un minimum. Jamais reçu aucne rĂ©ponse. Sur mon Mac sous Mojave, jâai dĂ» la dĂ©sinstaller car comportement catastrophique, inutilisable. Je nâai jamais vu depuis windows 98, une nouvelle appli apparaĂźtre avec autant de soucis dâentrĂ©e de jeu. Sur un autre Mac sous Catalina, un poil mieux mais encore trĂšs loin dâun fonctionnement acceptable. Quand je pointe vers mes âfavoris avec Qobuzâ, AS se plante immĂ©diatement. La faute Ă MacOS sans douteâŠ
Ne connaissant pas vraiment ROON, je me lancĂ© dans lâessai gratuit et ai donc pu comparer AS/A3.5 avec les possibilitĂ©s de ROON (oui ok, un poil plus cher) et lĂ il nây a pas vraiment photo. LâĂ©coute de mes albums me semble plus Ă©quilibrĂ©e, quelque soit le systĂšme dâĂ©coute choisi, modeste ou supĂ©rieur (ampli Ă tubes). AS et A3.5 est trĂšs bonne cotĂ© Ă©coute (timbres plus brillants mais aussi moins naturels) mais un poil moins bien que ROON, avec configs des chaines dâĂ©coute identiques Ă©videmment. Oui câest aussi une affaire dâĂ©coute purement subjective, nous ne sommes pas tous faits pareils. Cerise sur le gĂąteau, la gestion de la bibliothĂšque musicale de ROON est vraiment Ă©poustouflante. Les rĂ©glages ne sont pas toujours trĂšs faciles Ă localiser mais on sây fait. A noter ici surtout une stabilitĂ© de lâĂ©coute musicale au-dessus de tout de ce que jâai pu essayer et utiliser par le passĂ© pour le streaming. La diffĂ©rence de prix est alors totalement oubliĂ©eâŠ
Bonjour,
Oui on est bien dâaccord. Pour moi le positionnement prix dâAudirvana par rapport Ă Roon nâest pas cohĂ©rent. Roon est hyper stable, et est supĂ©rieur Ă Audirvana sur tout les plans. En tout cas en lecture rĂ©seau. Quite au payer une souscription autant de diriger vers Roon. Pour moi câest clair. Avec Roon on sait pourquoi on paie.
Câest amusant car câest exactement la raison pour laquelle je nâenvisage mĂȘme pas dâutiliser Roon : il ne fonctionne quâavec son systĂšme propriĂ©taire, donc juste une poignĂ©e de matĂ©riels estampillĂ©s âRoon Readyâ, contrairement Ă Audirvana qui est compatible avec le protocole standard DLNA/UPnP. Donc non, on peut pas vraiment parler de supĂ©rioritĂ© Ă ce niveau, quand on force les constructeurs et les consommateurs Ă utiliser sa solution privĂ©e au lieu dâun standard.
Bonjour,
Je peux comprendre votre remarque. Mais dans mon cas de figure, en utilisation rĂ©seau sur un Allo usbridge SIG, tout ou quasiment tout les OS tournant sur le Allo inclus un Roon bridge. Donc pour moi la question ne se pose pas dans ces termes. De plus maintenant il est quand mĂȘme rare de trouver un matĂ©riel n incluant pas dans ses options un Roon bridge.
Câest la force de Roon dâavoir pu imposer âRoon Readyâ. Beaucoup de fabricants de materiel ont suivi. Les clients qui achĂštent du matĂ©riel sont dâemblĂ©s tentĂ©s Ă sâabonner Ă Roon . Ăa fait dĂ©jĂ un grand parc dâabonner. En plus, le logiciel de Roon a des qualitĂ©s indĂ©niables.
Dans ce contexte, AS est positionnĂ© un peu cher par rapport Ă ce quâil offre et au tarif de ce concurrent.
Lâargument avancĂ© est tout Ă fait recevable⊠mais ROON fonctionne auusi avec des DAC non estampillĂ©s âRoon readyâ ! Sur le mien le âRoon readyâ est dĂ©sactivable, câest simplement un bouton soft Ă activer et dâailleurs dĂ©sactivĂ© par dĂ©faut, donc⊠Il fonctionne alors comme nâimporte quel autre DAC, avec Roon (non-ready) et A3.5/AS ou mconnect sous ios. Mon expĂ©rience aujourdâhui me montre simplement une Ă©coute extrĂȘmement stable (on pourrait mĂȘme dire âĂ toute Ă©preuveâ), Ă©quilibrĂ©e et naturelle. Roon va un peu plus loin. Ce qui ne veut pas dire que A3.5/AS ne peut pas faire lâaffaire pour ses utilisateurs, mais lui aussi a ses restrictions et quelques trucs pratiques en utilisation pas marrants du tout, un peu long Ă illustrer ici. NB : jâutilise Audirvana depuis ses dĂ©buts.
Oui, dâautant plus que le fabricant du matĂ©riel propose en gĂ©nĂ©ral une pĂ©riode dâessai relativement longue⊠et ce qui au final intĂ©resse les utilisateurs câest la qualitĂ© et le plaisir de lâĂ©coute, cĂ d le rĂ©sultat final. Le succĂšs de Roon nâest pas dĂ» au simple hasard.
Bien sĂ»r que ce nâest pas un hasard. Câest un excellent logiciel qui est Ă des annĂ©es lumiĂšres en avance sur les autres pour certains aspects. Sâil Ă©tait offert Ă la vente Ă un prix raisonnable, je lâaurais achetĂ©. Mais ça ne mâintĂ©resse pas Ă mâabonner, parce que je ne stream pas et je nâĂ©coute que ma propre musique. Et pour ça, il y a dâexcellents lecteurs dont on peut acheter la licence, tant pour mon Mac que mon PC.
Pour tirer le meilleur de Roon c est en lecture réseau qu il faut l utiliser. Donc un pc ou Mac pour faire tourner le Roon core, un lecteur réseau avec le Roon bridge connecté sur le dac et on commande le tout à partir de son smartphone avec l application Roon. Si on recherche une utilisation plus simple de l ordinateur directement en USB sur le dac alors Audirvana est une meilleure option si on privilégie la qualité de restitution. En lecture réseau Roon est trÚs bon mais il n est pas optimisé pour une lecture directe du pc au dac en USB.
