Bonjour,
j’ai un Mac OS 11.6 Audirvana studio en (phase de test)+ liaison USB + DAC M1click… je stream qobuz en FLAC 24 bits…je vois bien la source Ordinateur. FLAC 24 bits…mais en entrée du DAC j’ai du 16 bits/44kHhz…( curieux il bascule de 24 à 16 bits lorsque je fais lecture)…
je vous met mon debug report ci dessous:
Audirvana Studio 1.7.2 (10702)
macOS Version 11.6 (assemblage 20G165) with 8GB physical RAM
AUTO: /Users/srmac/Music/Qobuz
iTunes/Music library synchronization: last synchronized on Sat Oct 9 15:37:00 2021
Library database path: /Users/srmac/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 58395
BURR-BROWN FROM TI USB AUDIO DAC
Model UID:USB Audio DAC :08BB:2706
UID:AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14610000:1
Hog Mode is on
ID 0x41 USB Audio DAC
Manufacturer: Burr-Brown from TI
Model Name: Burr-Brown from TI USB Audio DAC
Model UID: USB Audio DAC :08BB:2706
UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14610000:1
3 available sample rates up to 48000Hz
32000
Stream ID 0x42 2 channels starting at 1
12 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
12 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x32 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0x41 USB Audio DAC Manufacturer: Burr-Brown from TI Model UID: USB Audio DAC :08BB:2706 UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14610000:1 Model Name: Burr-Brown from TI USB Audio DAC
