Alex
I just realised that not all the HD albums that I have in my local library are coming through:
A DSD64 file is played as 24/88
A 24/88 file is played as 24/88
A 24/48 file is played as 24/48
A 24/176 file is not producing any sound but the lecture says 24/96
A 24/96 file is not producing any sound but the lecture says 24/96
I use my phone whit usb audio player or my Mac book pro with audirvana and Smsl M500. And have fantastic sound, I put xlr outputs, Fabulous. I try another dac and streams above 3000€ or 4000€ and don’t have better sound, and smsl M500 is 380€
I haven’t heard back yet from Peachtree but I think it’s obvious that the DAC in the Nova is dated and is likely to be the source of the problems. I have placed an order for a Khadas toneboard DAC. I should have it here sometine in the week. I will share the results of my testing as soon as I get it. Thank you
Just read this thread and was going to suggest the Khadas TB. I think it sounds great, it has a slightly more analog sound than the DAC in my DX160. It has no noise/hiss that I can hear. It can compete against DACs that cost way more according to reviews. My Khadas TB is installed inside my amp using a short USB C extension lead so you can plug your usb lead from your computer into the back of the amp. I forgot to do the same with the coax input. The only issue I had was that my Mac did not recognise it straight away (it’s plug and play with no drivers) after I unplugged it, but it did with a bit of fiddling. It is MQA compatible which is ideal if you use Tidal.
Actually the Nova has a designated “room” in the back for a separate wireless device. I could probably use this space to adapt the KTB … however, I will probably keep it separate and take advantage to use it with my laptop and headphones.
My macbook pro is not recognising the Khadas tone board connected via USB.
I think I remember seeing this is not an uncommon issue.
Any ideas to make it work? I have been plugging-unplugging for a while.
I can go find a coax cable but I want to make USB work. Thanks
