Audirvana Mac Version 3.5.35 (3565)
macOS 10.11.6 with 4096MB RAM
Registered to JOSE BERMUDEZ
AU plugin #0: Effect - Voxengo Marvel GEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/perro1965/Music/HDtracks
AUTO: /Users/perro1965/Music/THE AUDIOPHILIAC MA RECORDINGS SAMPLER
Library database path: /Users/perro1965/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
Max. memory for audio buffers: 1056MB
Integer mode: Disabled
USB Audio DAC
Model UID:USB Audio DAC :08BB:2704
UID:AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14100000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x32 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:82 UID:AppleHDAEngineOutput:1B,0,1,1:0
5 available sample rates up to 96000Hz
32000
Stream ID 0x33 2 channels starting at 1
5 virtual formats:
20 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 AQUOS UID: uuid:dbda0c3c-0a78-11e1-9713-24264235F40C Location: http://192.168.0.172:12345/mrd/
