Thanks, here’s the debug…
Audirvana Origin 2.3.0 (20300)
macOS 12.6.5 with 16GB physical RAM
Connected account of : Jeff Halmos
No plugin active
r8brain with 2x upsampling
Phase minimum phase
SW volume control: ON
AUTO: /Users/jeffhalmos/DSD Recordings
iTunes/Music library synchronization: last synchronized on Wed Jan 4 22:32:52 2023
Library database path: /Users/jeffhalmos/DSD Recordings/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53029
Max. memory for audio buffers: 13356MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 384kHz
Active Sample Rate: 384kHz
Hog Mode is on
Selected device:SMSL USB AUDIO
Manufacturer: SMSL
Model name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
ID 0x46
Audio buffer frame size : 106 to 4096 frames
Max volume alert: Disabled
Stream ID 0x47 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x32 Built-in Output
Model UID: AppleHDA:128
Device #1: ID 0x46 SMSL USB AUDIO
Manufacturer: SMSL
Device #2: ID 0x3c Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 1
Device #0: Kitchen speaker
Model name: Google Home
