Audirvana Mac Version 1.6.4 (10604)
macOS 10.15.7 with 32768MB RAM
Connected account: XXXXXXXXXXXXXXXXXXXXXXXXXX
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 0 folders
Library database path: /Users/xxx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50297
Qobuz: Connected as Qobuz Hi-Fi Sublime
Exclusive access: Disabled
ATOLL ELECTRONIQUE ATOLL STREAMER
Model UID:ATOLL ELECTRONIQUE ATOLL STREAMER
UID:uuid:5F9EC1B3-FF59-19BB-8530-0011F6A9456B
Active Sample Rate: 48kHz
ID 0x4b Haut-parleurs MacBook Pro
Model Name: Apple Inc. Haut-parleurs MacBook Pro
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x4c 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4b Haut-parleurs MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Haut-parleurs MacBook Pro
UPnP devices found : 1
Device #0: ID 0x0 ATOLL STREAMER UID: uuid:5F9EC1B3-FF59-19BB-8530-0011F6A9456B Location: http://192.168.1.15:8080/description.xml
