Changing files with different sample rate => Plop
Hello @icekill, can you change the sample rate in audio midi setup? Do you hear a pop from your DAC when you do it?
Hello Damien,
I have:
1 - closed Audirvana.
2 - Opened the Audio Midi setup on my Mac mini.
3 - Changed the max sample rate from 2 ch 24 bits/192hz to a lower value.
Result: No pop at all in any other value.
I have installed Jriver trial for Mac. There is no pop at all for any sample change.
Maybe that a good solution would be to implement a function to switch off the audio output during the sample rate change in Audirvana. It would save the tweeters…
Can you send me a copy of the ā€œDebug Infoā€? You can get it in Audirvana Settings>General>Debug Info
macOS 10.13.6 with 16384MB RAM
Registered to David B
	AU plugin #0: Music Effect - Blue Cat Audio BC Gain 3 (Dual) ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
Sync list: 12 folders
AUTO: /Volumes/Itune/
AUTO: /Volumes/music/Ambient Lounge
AUTO: /Volumes/music/BOF
AUTO: /Volumes/music/Blues Jazz
AUTO: /Volumes/music/Classical
AUTO: /Volumes/music/Cold Wave - World
AUTO: /Volumes/music/Divers
AUTO: /Volumes/music/Electronic
AUTO: /Volumes/music/Lossless
AUTO: /Volumes/music/Pop Rock
AUTO: /Volumes/music/Raphael
AUTO: /Volumes/music/Voices
Library database path: /Users/Music/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 7520MB
Speaker
Model UID:CmediaUSBDSDDevice:Hegel USB Audio B
UID:CmediaUSBDSDEngine:C-Media Electronics Inc.:Hegel USB Audio B:fa120000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 44.1kHz
Hog Mode is on
ID 0x27 Speaker Manufacturer:C-Media Electronics Inc.
Model UID:CmediaUSBDSDDevice:Hegel USB Audio B UID:CmediaUSBDSDEngine:C-Media Electronics Inc.:Hegel USB Audio B:fa120000:1
Audio buffer frame size : 53 to 4096 frames
Stream ID 0x28 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x27 Speaker Manufacturer: C-Media Electronics Inc. Model UID: CmediaUSBDSDDevice:Hegel USB Audio B UID: CmediaUSBDSDEngine:C-Media Electronics Inc.:Hegel USB Audio B:fa120000:1
UPnP devices found : 1
Device #0: ID 0x0 RX-A2040 B65EE9 UID: uuid:5f9ec1b3-ed59-1900-4530-00a0deb65ee9 Location: http://192.168.1.11:8080/MediaRenderer/desc.xml
If you deactivate your plugin, do you still have the issue?
Yes, still poping with the effect disabled.
Can you try to disable Integer mode in the audio output settings of Audirvana?
Interger mode is now disabled.
1st try leads Audirvana to sound a very bad noise into my speakers.
3 other tries made Audirvana bug and quit brutally (with the report to send to Apple).
Not good!
Can you send us the latest report generated at [email protected]?
I have sent you the report.
I listen to everything modulated to DSD128 via SoX and I listen to raw binaural DSDxxx… The only ā€˜ticks’ I get are from bad editing of a DSD master file, between tracks…
2016 MacBook Pro
2.7 GHz Quad-Core Intel Core i7, 16 GB 2133 MHz LPDDR3
macOS 12.1 (Monterey)
Audirvana 1.10.2
All of my PCMxxx files are modulated to DSD128
Just adding some insight to your subjective observation… :sunglasses:
What is important is to look at the numbers of users that don’t have the problems you are so certain about, and why and where you believe they emanate… If you accept the fact that others do not have these problems, you may look beyond the myopia of your perspective and find a resolution to your experience…
