Voici Audirvana Studio 2.3.0 (20300)
macOS 13.2.1 with 16GB physical RAM
Connected account of : Jacques Garneau
Per track: OFF
r8brain custom frequencies
Bandwidth = 91.9666%
Stop band attenuation 188.284dB
Phase minimum phase
Max allowed volume: 0
AUTO: /Volumes/USB C1/Audirvana
iTunes/Music library synchronization: last synchronized on Sat Jun 4 11:15:01 2022
Library database path: /Users/jacquesgarneau/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 9916
Listening on 127.0.0.1 on port 55258
Active method: UPnP
Preferred device: [UPnP] M1T-Jacques Model UID:JF Light Industries UpMPD UID:uuid:5e46403c-c21c-abaf-6783-e45f0103ef98
Currently playing to UPnP device at 24 bits 2822.4kHz
Selected device:M1T-Jacques
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:5e46403c-c21c-abaf-6783-e45f0103ef98
UPnP device at http://192.168.2.60:49152/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: Yes
http-get:*:audio/l16:dlna.org_pn=lpcm
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:03:35
CurrentURI: http://192.168.2.63:49152/audirvana/audio_52.dff
CurrentURIMetadata:
dc:titleWhere Do the Children Play?</dc:title>
dc:creatorCat Stevens</dc:creator>
upnp:artistCat Stevens</upnp:artist>
upnp:genreFolk</upnp:genre>
upnp:albumArtURIhttp://192.168.2.63:49152/audirvana/artwork_0_48.jpg</upnp:albumArtURI>
upnp:albumTea For The Tillerman</upnp:album>
http://192.168.2.63:49152/audirvana/audio_48.dff
nextURI: http://192.168.2.63:49152/audirvana/audio_53.dff
nextURIMetadata:
dc:titleBut I Might Die Tonight</dc:title>
upnp:albumArtURIhttp://192.168.2.63:49152/audirvana/artwork_1_53.jpg</upnp:albumArtURI>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
PlayMedium: HDD
Current transport actions:
Next,Previous,Play,Stop,Seek
<?xml version="1.0"?>
1
1
M1T-Jacques
JF Light Industries
https://framagit.org/medoc92
UPnP front-end to MPD
UpMPD
42
https://framagit.org/medoc92/upmpdcli/code/
upmpdcli version 1.4.12 libupnpp 0.20.1
<qq:X_QPlay_SoftwareCapability xmlns:qq=“http://www.tencent.com”>QPlay:2</qq:X_QPlay_SoftwareCapability>
image/png
64
64
32
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/icon.png
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/presentation.html
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-schemas-upnp-org-service-AVTransport-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-schemas-upnp-org-service-AVTransport-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-schemas-upnp-org-service-AVTransport-1
urn:schemas-tencent-com:service:QPlay:2
urn:tencent-com:serviceId:QPlay
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-schemas-tencent-com-service-QPlay-2.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-schemas-tencent-com-service-QPlay-2
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-schemas-tencent-com-service-QPlay-2
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-schemas-upnp-org-service-RenderingControl-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-schemas-upnp-org-service-RenderingControl-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-schemas-upnp-org-service-RenderingControl-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-schemas-upnp-org-service-ConnectionManager-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-schemas-upnp-org-service-ConnectionManager-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-schemas-upnp-org-service-ConnectionManager-1
urn:av-openhome-org:service:Info:1
urn:av-openhome-org:serviceId:Info
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Info-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Info-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Info-1
urn:av-openhome-org:service:Time:1
urn:av-openhome-org:serviceId:Time
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Time-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Time-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Time-1
urn:av-openhome-org:service:Volume:1
urn:av-openhome-org:serviceId:Volume
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Volume-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Volume-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Volume-1
urn:av-openhome-org:service:Credentials:1
urn:av-openhome-org:serviceId:Credentials
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Credentials-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Credentials-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Credentials-1
urn:av-openhome-org:service:Playlist:1
urn:av-openhome-org:serviceId:Playlist
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Playlist-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Playlist-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Playlist-1
urn:av-openhome-org:service:Radio:1
urn:av-openhome-org:serviceId:Radio
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Radio-1.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Radio-1
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Radio-1
urn:av-openhome-org:service:Product:2
urn:av-openhome-org:serviceId:Product
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/urn-av-openhome-org-service-Product-2.xml
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/ctl-urn-av-openhome-org-service-Product-2
/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/evt-urn-av-openhome-org-service-Product-2
1
1
M1T-Jacques
JF Light Industries
UpMPD
42
image/png
64
64
32
UPnP devices found : 7
Device #0: ID 0x0 : Yamaha WXA 50
UID: uuid:9ab0c000-f668-11de-9976-ac44f282e4d6
Location: http://192.168.2.47:49154/MediaRenderer/desc.xml
Manufacturer: Yamaha Corporation
Model name: WXA-50
Device #1: ID 0x0 : MA1 07AEBA
UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d107aeba
Manufacturer:
Model name: eDMP3.9_CE2
Device #2: ID 0x0 : A7_055828
UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d1055828
Manufacturer: Bowers & Wilkins
Model name: A7
Device #3: ID 0x0 : A7_05134C
UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d105134c
Model name: A7
Device #4: ID 0x0 : M1T-Jacques
Location: http://192.168.2.60:49152/uuid-5e46403c-c21c-abaf-6783-e45f0103ef98/description.xml
Model name: UpMPD
Device #5: ID 0x0 : AVR10-Jacques
UID: uuid:10369153-024d-43c3-9ae0-cd0b0c982960
Location: http://192.168.2.64:39015/10369153-024d-43c3-9ae0-cd0b0c982960.xml
Manufacturer: Harman Luxury Audio
Model name: ARCAM AVR10
Device #6: ID 0x0 : [TV] Samsung
UID: uuid:08583b02-008c-1000-8d84-84a466955171
Manufacturer: Samsung Electronics
Model name: UN75H7100
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Local devices found : 4
Device #0: ID 0x8d M1-Jacques
Manufacturer: Apple, Inc.
Model UID: 7B:5B:4E:44:7F:12-69410420233980-airplay
Model name: Apple, Inc. M1-Jacques
Device #1: ID 0xc0 ARC AV AMP
Model UID: AppleGFXHDA:0
UID: AppleGFXHDAEngineOutputDP:f803:0:{2921-0001-01010101}
Model name: Apple Inc. ARC AV AMP
Device #2: ID 0x60 Haut-parleurs Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs Mac mini
Device #3: ID 0x31 Appareil agrégé
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Appareil agrégé
Chromecast devices found : 1
Device #0: AVR10-Jacques
