AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/Shared/Music
Library database path: /Users/hernlund/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6912MB
D90 MQA
Model UID:D90 MQA:152A:8750
UID:AppleUSBAudioEngine:Topping:D90 MQA:14200000:1
Sample rate switching latency: 4s
ID 0x29 D90 MQA Manufacturer:Topping
Model UID:D90 MQA:152A:8750 UID:AppleUSBAudioEngine:Topping:D90 MQA:14200000:1
MQA Decoder device
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:40 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x89 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:40 UID: AppleHDAEngineOutputDP:0,1,0,1,1:0:{D94D-4D03-01010101}
Device #2: ID 0x29 D90 MQA Manufacturer: Topping Model UID: D90 MQA:152A:8750 UID: AppleUSBAudioEngine:Topping:D90 MQA:14200000:1
