Issue just happened again:
Audirvana Studio 2.8.1 (20801)
macOS 14.4.1 with 32GB physical RAM
Connected account of : John Frech
AUTO: /Volumes/hi rez music/Music
Library database path: /Users/johnfrech/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Deep Synch: yes
Scanning 18548/13584: /Volumes/hi rez music/Music/RoonBackups/5049da23-9f88-873a-4479-7172d40f9449/af/ff
Fingerprinting track 662/2649 : /Volumes/hi rez music/Music/Ciaccona (Pure DSD) - EUDDR1803/DSD 128fs - 2ch/10. Chaconne, from the Partita BWV 1004 DSD 128fs - 2ch.dsf
Listening on 127.0.0.1 on port 49319
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 8282MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
[UPnP] dCS Vivaldi Upsampler (51210)
Model UID:Data Conversion Systems Ltd Vivaldi Upsampler
UID:uuid:ffc61b75-3523-4594-9f4b-b4fb27fb5f02
Selected device:Built-in Output
Model UID: AppleHDA:16
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
ID 0x54
3 available sample rates up to 96000Hz
Not automatically detected, user set to MQA Decoder
DSD via PCM 1.1
Stream ID 0x55 2 channels starting at 1
3 virtual formats:
3 physical formats
Device #0: ID 0x54 Built-in Output
Device #1: ID 0x47 ZoomAudioDevice
Manufacturer: zoom.us
Model UID: zoom.us.zoomaudiodevice
UID: zoom.us.zoomaudiodevice.001
Model name: zoom.us ZoomAudioDevice
UPnP devices found : 1
Device #0: ID 0x0 : Living Room
UID: uuid:a73b1df4-4da4-19f4-0080-0005cdb1302a
Location: http://192.168.1.39:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon AVR-X2600H
