A Origin 2.3.2 on macOS 10.14
I found some doubled tracks in the search menu and wanted to delete one of them. I opened the album out of the search view and selected the 3 dots menu on the left of the track, “Delete” was grayed out. When I went from Album view to the same tracks, Delete worked properly.
@Antoine: Can you reproduce that?
Hi @o99,
this is something I’m aware of. For the moment you can only remove a tracks when you are in the Local section but It will change at some point in the future.
