Audirvana Origin 2.4.0 (20400), MacOS 10.14
Since this update some Album Art is not not shown in search results in the title category. These tracks are duplicates, that do not exist. Clicking on “Show All” the Album Art is shown correctly, as it should, but still not existing duplicate tracks.
I did all the maintenance routines: no change. @Antoine : Can you reproduce that on your side?
As reported here Deleting tracks not always possible deleting duplicate tracks is only possible in Album view, because the 3 dot menu only works there. So solving the duplicate files issue becomes a Sysiphos work. Please correct that in near future.
I would like to perform the same search as you have done and with your database file. Can you send me a mail at support@audirvana.com so you can upload the file to my OneDrive?
Hi, I wanted to bump this thread and say that I’m seeing the same issue: loads of duplicate tracks in my library. I’m using Studio on macOS and my library files are on an external HD. Could that be the issue?
Hi gcaprio
The HD isn’t the problem. If there are no duplicate tracks on your HD, the following procedure helped after having discussed that with Audirvana support:
Backup your library with the command in the preferences.
Delete your HD in the list of sources in the preferences of A and quit it.
Delete the file AudirvanaDatabase.sqlite in user/…/Library/Aplication Support/Audirvana
Restart A and add your HD to the sources of A. A reads your files and produces a new database.
After this process has finished, restore your library from your backup.
