Well… there polynesian french, canadian french, stubborn french… there is a lot of french out there, so much you can even start to think there french ![]()
Don’t forget Cajun…
Ok… ben écoute je teste ça et je reviens vers toi si je rencontre un souci…
Mais je devrais m’en tirer
MErci ![]()
No. Never. Couldn’t even consider it.
So pleased you get the spirit of the banter on here @dh3rm3 ![]()
Pas de problème.
Si l’impossibilité de streamer du DSD est dû à la configuration de DietPi, je ne sais pas si je pourrai vous aider, parce qu’il s’agit d’une distribution Linux que je n’ai jamais essayée.
On va voir
Si je peux conserver Audirvana et streamer du DSD déjà ça sera bien
Just a random question @Cloclo : Did you try Allo Usbridge with Audirvana ? Worth for me to try the upgrade from Hifiberry Digi + ?
So… I was not too far off investigating the Linux implementation… Pretty good guess for a Audirvana user with poor networking competency using these devices…
Value is in trying… Modesty lays in succeeding… in between hard work.
Allo USBridge Sig is one of the streamers that I have. It’s very good.
I never tried the Hifiberry Digi +, so I cannot tell you if it’s worth upgrading.
As long as it works with Audirvana and RopieeeXL I’m good
You wasted his time with irrelevant advices during three days.
There are plenty of audiophile Linux distributions, and DietPi is among the ones I never tried, and have no reason to try it.
RopeeeXL is one of the Linux distributions that works very well with Audirvana.
@Cloclo … Where were you then? I was hoping you would jump in… I did my best to help… Why must you be such a “bit”?
To quote the great author @AndyLubke “why don’t y’all get a room”
Love fest is over by popular demand
Where I was is not your business.
I’m not Antoine, and providing support is not my job.
I came across this thread this evening, and saw the discussion between you, and @dh3rm3 .
Okay… So there is no reason to be so rude to me…
Instead of helping him, you wasted his time with irrelevant advices.
Why can’t you refrain from posting on topics with which you are not familiar?
It’s counterproductive, and creates frustration as a guy needs help.
Apparently it attracted your attention… so, my engagement in reaching a solution was fruitful… Why are you such a “bit”?
Pulls up chair, gets bowl of popcorn, and settles back to enjoy.
This thread could run further (and longer) than Forrest Gump
