Hello to the community,
I’ll try to be as brief and clear as possible to describe the problem I encounter:
My system is as follows :
MacOS Big Sur → Audirvana Origin 2.2.3 (installed today, I’ll expand on this later on) → files from USB external 4TO WD drive connected to the mac → RBP4 Dietpi (latest version, updated tonite also) via eth cat 7 cable → USB to Musician Pegasus DAC.
Dietpi is shown as available in the audio setting : when I select it : there is no option to do DOP (DSD over PCM). The option is simply missing (see screenshot)
While if I select my macbook internal dac the DOP option is there.
So when I try to play any dsf file, nothing happens on the side of the dac, as MacOS can only do DOP and can’t send native DSD.
How do I activate DOP in this case ?
To be more thorough :
my DAC does supports DOP as follows : ( DSD64-DoP On All Input, DSD1024 On USB & I2S Input) source : (Musician Pegasus website)
Dietpi sees my dac :
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Audio [MUSICIAN USB HiRes Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
root@DietPi:~#
The problem is I cannot activate DOP into audirvana.
Audirvana wants to send native DSD files to the dac, which anyway can’t be done in MacOS
A debug info will show me : DSD capability: Raw DSD (MSB), but it should be DOP as I’m on macOS anyway…
Something escape my mind here.
Any people had the same problem ?
I was running Audirvana 3.5, but as I was confronted with the same situation, I decided to try origin (to be up to date), but the problem is still the same.
I update my dietpi to the latest version tonite, thinking it might come from here.
Deleted my audirvana pref files. Rebooted, reinstall.
Still the same. i can’t play dsf files to the DAC.
Every other format and bitrate and frequency work fine.
Any idea is welcome.
Thanks in advance !
Here is my debug info :
Audirvana Origin 2.2.3 (20203)
macOS Version 11.1 (Build 20C69) with 16GB physical RAM
Connected account of : Alain CAILHOL
AUTO: /Volumes/caravage/-done
Library database path: /Users/dh3rm3/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 58093
Active method: UPnP
Preferred device: [UPnP] DietPi Model UID:Ivo Clarysse, Henner Zeller gmediarender UID:uuid:ba2dc31a-314d-407a-90af-c7a44685f75e
Selected device:DietPi
Manufacturer: Ivo Clarysse, Henner Zeller
Model name: gmediarender
Model UID: Ivo Clarysse, Henner Zeller gmediarender
UID: uuid:ba2dc31a-314d-407a-90af-c7a44685f75e
UPnP device at http://192.168.1.105:49494/description.xml
ID 0x0
2822400
5644800
11289600
22579200
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get::application/x-subtitle-vtt:
http-get::application/x-subtitle-lrc:
http-get::application/x-subtitle-qttext:
http-get::application/x-subtitle-dks:
http-get::application/x-subtitle-mpl2:
http-get::application/x-subtitle-tmplayer:
http-get::application/x-subtitle-sami:
http-get::application/x-subtitle:
http-get::application/vnd.ms-sstr+xml:
http-get::application/x-teletext:
http-get::application/x-3gp:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::video/mj2:
http-get::video/quicktime:
http-get::video/x-qt-part:
http-get::video/x-mp4-part:
http-get::image/x-exr:
http-get::raw/x-pcap:
http-get::application/ttml+xml:
http-get::audio/x-xi:
http-get::audio/x-w64:
http-get::audio/x-svx:
http-get::audio/x-sds:
http-get::audio/x-rf64:
http-get::audio/x-paris:
http-get::audio/x-nist:
http-get::audio/x-ircam:
http-get::video/x-fli:
http-get::audio/x-private-ts-lpcm:
http-get::audio/x-private2-lpcm:
http-get::audio/x-private1-lpcm:
http-get::video/webm:
http-get::audio/webm:
http-get::video/x-matroska-3d:
http-get::video/x-matroska:
http-get::audio/x-matroska:
http-get::application/x-subtitle-unknown:
http-get::application/x-usf:
http-get::video/x-av1:
http-get::audio/x-wav:
http-get::application/vnd.rn-realmedia:
http-get::application/x-pn-realaudio:
http-get::application/x-rdt:
http-get::subpicture/x-pgs:
http-get::multipart/x-mixed-replace:
http-get::application/x-bzip:
http-get::audio/x-amr-wb-sh:
http-get::audio/x-amr-nb-sh:
http-get::audio/x-private1-ac3:
http-get::audio/x-wavpack:
http-get::audio/x-stm:
http-get::audio/x-s3m:
http-get::audio/x-it:
http-get::audio/x-xm:
http-get::audio/x-vgm:
http-get::audio/x-spc:
http-get::audio/x-sap:
http-get::audio/x-nsf:
http-get::audio/x-kss:
http-get::audio/x-hes:
http-get::audio/x-gym:
http-get::audio/x-gbs:
http-get::audio/x-ay:
http-get::audio/x-private1-dts:
http-get::audio/x-mod:
http-get::image/webp:
http-get::application/dash+xml:
http-get::application/x-gdp:
http-get::audio/x-midi-event:
http-get::application/x-dtls:
http-get::audio/x-lpcm:
http-get::audio/x-unaligned-raw:
http-get::video/x-unaligned-raw:
http-get::audio/x-sid:
http-get::video/x-ms-asf:
http-get::text/plain:
http-get::application/kate:
http-get::video/ogg:
http-get::audio/ogg:
http-get::text/x-cmml:
http-get::video/x-daala:
http-get::video/x-smoke:
http-get::application/x-ogm-audio:
http-get::application/x-ogm-video:
http-get::application/x-ogm-text:
http-get::application/ogg:
http-get::application/x-ogg-avi:
http-get::subpicture/x-dvd:
http-get::application/x-kate:
http-get::subtitle/x-kate:
http-get::video/x-flv:
http-get::audio/riff-midi:
http-get::audio/midi:
http-get::image/svg+xml:
http-get::image/svg:
http-get::image/x-bitmap:
http-get::image/vnd.wap.wbmp:
http-get::image/x-ms-bmp:
http-get::image/x-bmp:
http-get::image/x-portable-pixmap:
http-get::image/x-portable-bitmap:
http-get::image/x-pixmap:
http-get::image/x-cmu-raster:
http-get::application/x-navi-animation:
http-get::image/x-icon:
http-get::video/x-msvideo:
http-get::application/x-subtitle-avi:
http-get::subpicture/x-dvb:
http-get::text/x-raw:
http-get::application/x-apetag:
http-get::application/x-hls:
http-get::application/x-ssa:
http-get::application/x-ass:
http-get::audio/x-au:
http-get::application/sdp:
http-get::application/x-icy:
http-get::video/x-dirac:
http-get::audio/ac3:
http-get::audio/x-bv:
http-get::audio/x-celt:
http-get::audio/x-ilbc:
http-get::audio/g723:
http-get::video/x-jpeg:
http-get::meta/x-klv:
http-get::audio/x-sbc:
http-get::audio/x-siren:
http-get::audio/x-speex:
http-get::audio/x-vorbis:
http-get::application/x-srtcp:
http-get::application/x-srtp:
http-get::application/x-rtcp:
http-get::application/x-srtcp-stream:
http-get::application/x-srtp-stream:
http-get::application/x-rtcp-stream:
http-get::application/x-rtp-stream:
http-get::application/x-rtp:
http-get::video/x-cdxa:
http-get::video/x-sonix:
http-get::video/x-pwc2:
http-get::video/x-pwc1:
http-get::video/x-bayer:
http-get::video/mpegts:
http-get::application/x-id3:
http-get::audio/x-dv:
http-get::audio/x-smpte-302m:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/x-ffmpeg-parsed-ape:
http-get::audio/x-vnd.sony.atrac1:
http-get::audio/x-dsd:
http-get::audio/x-eac3:
http-get::audio/x-flac:
http-get::audio/x-gsm:
http-get::audio/ms-gsm:
http-get::audio/x-imc:
http-get::audio/x-mlp:
http-get::audio/x-gst-av-mp3adufloat:
http-get::audio/x-gst-av-mp3on4float:
http-get::audio/x-ffmpeg-parsed-musepack:
http-get::audio/x-nellymoser:
http-get::audio/x-opus:
http-get::audio/qcelp:
http-get::audio/x-qdm2:
http-get::audio/x-pn-realaudio:
http-get::audio/x-shorten:
http-get::audio/x-sipro:
http-get::audio/x-true-hd:
http-get::audio/x-truespeech:
http-get::audio/x-twin-vq:
http-get::audio/x-gst-av-vmdaudio:
http-get::audio/x-wms:
http-get::audio/x-gst-av-ws_snd1:
http-get::audio/x-dpcm:
http-get::audio/g722:
http-get::video/x-aasc:
http-get::video/x-apple-intermediate-codec:
http-get::video/x-amv:
http-get::video/x-asus:
http-get::video/x-gst-av-avs:
http-get::video/x-cavs:
http-get::video/x-cineform:
http-get::video/x-cirrus-logic-accupak:
http-get::video/x-camstudio:
http-get::video/x-compressed-yuv:
http-get::video/x-gst-av-8bps:
http-get::video/x-ffv:
http-get::video/x-gst-av-ffvhuff:
http-get::video/x-flash-screen:
http-get::video/x-flash-screen2:
http-get::video/x-gst-av-flic:
http-get::video/x-fraps:
http-get::image/gst-libav-gif:
http-get::video/x-h261:
http-get::video/x-intel-h263:
http-get::video/x-h265:
http-get::video/x-huffyuv:
http-get::video/x-gst-av-idcinvideo:
http-get::video/x-indeo:
http-get::video/x-gst-av-interplayvideo:
http-get::image/jp2:
http-get::image/x-jpc:
http-get::image/x-j2c:
http-get::video/x-kmvc:
http-get::video/x-lagarith:
http-get::video/x-loco:
http-get::video/x-gst-av-mdec:
http-get::video/x-mimic:
http-get::video/x-mjpeg-b:
http-get::video/x-gst-av-mmvideo:
http-get::video/x-msvideocodec:
http-get::video/x-mszh:
http-get::video/x-nuv:
http-get::image/x-portable-anymap:
http-get::image/pbm:
http-get::image/x-pcx:
http-get::image/x-portable-graymap:
http-get::video/x-gst-av-pgmyuv:
http-get::image/ppm:
http-get::video/x-prores:
http-get::video/x-qdrw:
http-get::video/x-gst-av-qpeg:
http-get::video/x-rle:
http-get::video/x-gst-av-roqvideo:
http-get::video/x-apple-video:
http-get::image/x-sgi:
http-get::video/x-smc:
http-get::video/sp5x:
http-get::image/x-sun-raster:
http-get::image/x-tga:
http-get::image/tiff:
http-get::video/x-truemotion:
http-get::video/x-camtasia:
http-get::video/x-tscc:
http-get::video/x-ultimotion:
http-get::video/x-ati-vcr:
http-get::video/x-gst-av-vmdvideo:
http-get::video/x-vmnc:
http-get::video/x-vp3:
http-get::video/x-vp5:
http-get::video/x-vp6:
http-get::video/x-vp6-alpha:
http-get::video/x-vp6-flash:
http-get::video/x-vp9:
http-get::video/x-gst-av-vqavideo:
http-get::video/x-gst-av-wnv1:
http-get::video/x-xan:
http-get::video/x-gst-av-xl:
http-get::video/x-zmbv:
http-get::unknown/unknown:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::application/x-ape:
http-get::application/x-gst-av-avs:
http-get::audio/x-bfstm:
http-get::audio/x-brstm:
http-get::application/x-gst-av-daud:
http-get::application/x-gst-av-dsf:
http-get::application/x-gst-av-ea:
http-get::video/x-4xm:
http-get::image/gif:
http-get::application/gxf:
http-get::application/x-gst-av-idcin:
http-get::application/x-gst-av-ipmovie:
http-get::video/x-ivf:
http-get::application/x-gst-av-mm:
http-get::application/x-gst-av-mmf:
http-get::audio/x-musepack:
http-get::application/mxf:
http-get::video/x-nsv:
http-get::application/x-gst-av-nut:
http-get::application/x-gst-av-nuv:
http-get::video/x-pva:
http-get::application/x-gst-av-film_cpk:
http-get::application/x-gst-av-smk:
http-get::application/x-gst-av-sol:
http-get::application/x-gst-av-psxstr:
http-get::audio/x-ttafile:
http-get::application/x-gst-av-vmd:
http-get::audio/x-voc:
http-get::application/x-gst-av-wc3movie:
http-get::application/x-gst-av-wsaud:
http-get::application/x-gst-av-wsvqa:
http-get::application/x-yuv4mpeg:
http-get::video/x-msmpeg:
http-get::audio/x-wma:
http-get::audio/g729:
http-get::image/bmp:
http-get::video/x-vp8:
http-get::video/x-dv:
http-get::video/x-svq:
http-get::audio/x-mace:
http-get::audio/x-adpcm:
http-get::audio/x-alaw:
http-get::audio/x-mulaw:
http-get::image/png:
http-get::audio/x-dts:
http-get::video/x-dnxhd:
http-get::audio/x-vnd.sony.atrac3:
http-get::video/x-pn-realvideo:
http-get::video/x-cinepak:
http-get::image/jpeg:
http-get::video/x-flash-video:
http-get::video/x-h264:
http-get::video/x-h263:
http-get::video/x-divx:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/x-scpls:
http-get::audio/x-mpeg:
http-get::audio/mpeg:
http-get::audio/amr-wb:
http-get::audio/amr:
http-get::audio/x-tta:
http-get::video/x-wmv:
http-get::video/mpeg:
http-get::audio/x-ac3:
http-get::video/x-raw:
http-get::video/x-theora:
http-get::audio/:*
http-get::audio/x-raw:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
35 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 1
MediaDuration:
CurrentURI: http://192.168.1.2:49153/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NOT_IMPLEMENTED
Current transport actions:
PLAY
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 DietPi Ivo Clarysse, Henner Zeller http://github.com/hzeller/gmrender-resurrect gmediarender 0.0.8 gmediarender 0.0.8 http://github.com/hzeller/gmrender-resurrect uuid:ba2dc31a-314d-407a-90af-c7a44685f75e image/png 64 64 24 /upnp/grender-64x64.png image/png 128 128 24 /upnp/grender-128x128.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.1.105:49494/Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 DietPi Ivo Clarysse, Henner Zeller http://github.com/hzeller/gmrender-resurrect gmediarender 0.0.8 gmediarender 0.0.8 http://github.com/hzeller/gmrender-resurrect uuid:ba2dc31a-314d-407a-90af-c7a44685f75e image/png 64 64 24 /upnp/grender-64x64.png image/png 128 128 24 /upnp/grender-128x128.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.1.105:49494/UPnP devices found : 1
Device #0: ID 0x0 : DietPi
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Device #0: ID 0x3b Built-in Output
Model UID: AppleHDA:94
