Can you take a snapshot of the options you have?
Should i use the large buffer
Can you click on the DSD playback options just to see what you have there.
Ok, you’re fine with that. Your DAC operates internally at DSD128. What’s the resolution if the file you’re trying to play?
Aha, select DSD128 for the upsampling rate.
24 192 ,but isnt the Dsj supposed to convert everything to 20 time dsd
With this setting you’re telling Audirvana to do the upsampling. If you want your DAC to do the upsampling, you need to disable upsampling in Audirvana.
Ok
Ok how do i do that now dsd is showing in audervana
You need a real DSD file or enable upsampling in Audirvana to DSD128.
Ok did that still didnt work but your great thank you so much for yoir help but i think its back to ps audio
Does it play at all?
Yes and sounds good just not doing dsd on ps audio dsj
Now if i play a downloaded DSD FILE i have it playsit in dsd
Wow your text is gone,but its says no volume control
