With upsampling it should play in DSD also the PCM content.
Yep
Do you have some effects plugin enabled?
I turned the volume down on the p.c
And now this
You can’t do that with DSD. Both volume control and plugins need to be disabled.
Yep, that’s it.
How do i disable volume on p.c
You had the setting above. Make sure that in DAC settings you have exclusive access turned on.
Yes it turn on automatically when i play an audio file
Wow the whole te the volume now i can do dsd 256 out i2s fr smsl to dsj
I would let the DAC do it’s thing without upsampling. It’s a special one.
So i shoould go back to 128?
I would play all files at their native resolution and let the Junior do its magic.
Well now im lost again how do i set it there ,did say thank you thank you thank you thank you
Hey ive got the dsd sigma delta modulator filyer on the B 8th order is that good
You can try if that sounds better to you. This thing already uses Ted Smith’s algorithms. It’s hard to improve on that. But tastes are tastes…
Ok which setting is that you tell me where ill try it
Just disable upsampling and it will play bit-perfect to the DAC. Your DAC will then upsample it to 10xDSD and then downsample it to 2xDSD, pass it through discrete low-pass filter circuit and you get music.
Can you send me a screen shot of that
