I just bought a DSD 256 file, and it plays back at 384kz! (On Roon it plays back as DSD 128.) My DSD 128 and 64 files play at the proper resolution. I’m using the latest version of Audirvana on a MacBook Pro. Yes, I have the audio set to DSD over PCM1.1. My DAC is built-into my McIntosh MA 9000, which can handle DSD 256. What might be the issue?
Wrong audio out maybe? Maybe not all can play max dsd256
Maybe something’s wrong with the file. Try to download a sample file from 2L.
I downloaded a DSD 256 from 2L–it also plays back at just 384. It must be a limitation of Audirvana.
Check also the DAC specification, if it supports DSD256 in DoP.
Otherwise it might be an Audirvana bug.
Hmm…my DAC only plays PCM up to 384, so that would prevent it from playing back at DSD 256, but that’s enough for DSD 128, so I don’t understand why Roon plays it at DSD 128 but Audirvana only at 384kHz.
Hello @Guitar1, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.3 with 8192MB RAM
Registered to
McIntosh-HD HS USB Audio
Model UID:McIntosh-HD HS USB Audio:2AFD:0005
UID:AppleUSBAudioEngine:McIntosh:McIntosh HD USB Audio:14140000:2
Active Sample Rate: 96kHz
ID 0x5c McIntosh-HD HS USB Audio Manufacturer:McIntosh
Model UID:McIntosh-HD HS USB Audio:2AFD:0005 UID:AppleUSBAudioEngine:McIntosh:McIntosh HD USB Audio:14140000:2
32000
Stream ID 0x5d 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Device #0: ID 0x5c McIntosh-HD HS USB Audio Manufacturer: McIntosh Model UID: McIntosh-HD HS USB Audio:2AFD:0005 UID: AppleUSBAudioEngine:McIntosh:McIntosh HD USB Audio:14140000:2
Device #1: ID 0x4b MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
That didn’t work–and upon closer inspection of my DAC’s display, it’s actually playing back at 352.8 kHz!
Do you get music or just noise?
Music–just not at the correct resolution.
That means that for whatever reason you’re playing PCM, not DSD over PCM. Check if accidentally you have convert DSD to PCM option enabled.
No, I have DSD over PCM1.1 selected.
Could you generate debug info dump while playing the DSD256 file.
Registered to
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x57 McIntosh-HD HS USB Audio Manufacturer:McIntosh
32000
Stream ID 0x58 2 channels starting at 1
36 virtual formats:
54 physical formats
Device #0: ID 0x57 McIntosh-HD HS USB Audio Manufacturer: McIntosh Model UID: McIntosh-HD HS USB Audio:2AFD:0005 UID: AppleUSBAudioEngine:McIntosh:McIntosh HD USB Audio:14140000:2
Can you set MQA setting to Non MQA. It’s puzzling, do you see on the Amp the resolution at which you play? Which model of the DAC module do you have?
I turned off MQA–didn’t help. My McIntosh MA9000 has the DA1 Digital Audio Module. Yes, I can see the resolution displayed. I see that the debug info shows a sampling rate of 352.8–it should be DSD128! (My DAC only supports PCM up to 368kHz) As I mentioned earlier, it plays back on Roon at DSD128 with the same DSD over PCM setting. Definitely weird!
Contact the manufacturer too. Maybe they can give you a hint.
Since it works just fine with Roon, I don’t think it’s the DAC. It would be nice if Audirvana offered native DSD playback. Is there some reason they don’t?
