I’ve got lots of issues playing tracks in Audirvana. Sometimes it just skips a track and starts the next, and sometimes it skips parts of the track in the middle of a song. Also plays the same track again when I skip to the next track. Very often it stops playback after a track, and I have to manually start the next one.
Surprised to see how many bugs this software has after so many years of development.
Hello @rubjel, The audio playback do not only rely on Audirvana, it also rely on your DAC and how you are connected to it. Thus I would need more information to help you.
HI there.
I have just paid for my Audirvana subscription and having similar issues to the user above. Essentially I can play one or two tracks with no issues and then the software stops working and freezes. If I skip a track it sometimes just repeats the same track again etc. It may be that I have incorrect settings etc but it all seems to work correctly using Roon or Linn Kazoo etc. I use an IMAC and have a Linn DSM as my streaming device.
Audirvana 3.5.38
Sync list: 0 folders
Library database path: C:\Users\Rune\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1262MB
Local Audio Engine:ASIO 2 driver version 2
Sotm200Ultra
Model UID:JF Light Industries Sotm200Ultra
UID:uuid:b7420a11-d68d-0551-5ede-029103817142
ASIO4ALL v2 Manufacturer:
Model UID:ASIO4ALL v2 UID:ASIO4ALL v2
Local devices found : 4
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #1: iFi (by AMR) HD USB Audio Manufacturer: Model UID: iFi (by AMR) HD USB Audio UID: iFi (by AMR) HD USB Audio
Device #2: JRiver Media Center 24 Manufacturer: Model UID: JRiver Media Center 24 UID: JRiver Media Center 24
Device #3: Prism Sound Orpheus Manufacturer: Model UID: Prism Sound Orpheus UID: Prism Sound Orpheus
Hello @rubjel, sorry for the delay, does the issue you have appear with all of your device or only with your Sotm?
Hello @craigborland1,
Hi Damien, I only use the Sotm streamer. Streaming from Audirvana on my laptop to the sotm via upnp.
This works perfectly with both Roon from my laptop and Bubbleupnp on my android phone.
In your debug info I see that you have selected ASIO4All, can you select your SoTm instead and send the debug info again?
Hi, yes I would except my trial expired a week ago unfortunately.
I’d love to have Audirvana, but with all the issues I experienced I think a lifetime subscription is a bit too much. I wish there was a one year option.
With Audirvana you just flat out buy a license. There is no subscription.
If you would like to, I can give you a trial extension to figure this issue out
Hi yes thanks, that would be excellent!
Hi again Damien, to follow up on my issues with Audirvana playback here is a log from today:
Audirvana 3.5.40
Preferred device: Sotm200Ultra Model UID:JF Light Industries Sotm200Ultra UID:uuid:b7420a11-d68d-0551-5ede-029103817142
UPnP device at http://192.168.1.47:49152/uuid-b7420a11-d68d-0551-5ede-029103817142/description.xml
Sotm200Ultra Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Sotm200Ultra JF Light Industries https://opensourceprojects.eu/u/medoc/profile/ UPnP front-end to MPD UpMPD 42 https://opensourceprojects.eu/p/upmpdcli/code/ upmpdcli version 1.4.5 libupnpp 0.17.2 image/png 64 64 32 /uuid-b7420a11-d68d-0551-5ede-029103817142/icon.png /uuid-b7420a11-d68d-0551-5ede-029103817142/presentation.html uuid:b7420a11-d68d-0551-5ede-029103817142 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Info-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Info-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Time-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Time-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Volume-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Volume-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Playlist-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Radio-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Radio-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Receiver-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Receiver-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Receiver-1 urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /uuid-b7420a11-d68d-0551-5ede-029103817142/urn-av-openhome-org-service-Product-1.xml /uuid-b7420a11-d68d-0551-5ede-029103817142/ctl-urn-av-openhome-org-service-Product-1 /uuid-b7420a11-d68d-0551-5ede-029103817142/evt-urn-av-openhome-org-service-Product-1UPnP devices found : 1
Device #0Sotm200Ultra UID: uuid:b7420a11-d68d-0551-5ede-029103817142 Location: http://192.168.1.47:49152/uuid-b7420a11-d68d-0551-5ede-029103817142/description.xml
Max. memory for audio buffers: 1554MB
Local Audio Engine:WASAPI
Device #0: Høyttalere (High Definition Audio Device) Manufacturer: Model UID: Høyttalere (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{eb269914-7554-4396-b677-0fd0eea7dac5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: JRiver Media Center 24 (JRiver Media Center 24) Manufacturer: Model UID: JRiver Media Center 24 (JRiver Media Center 24) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{384d6858-e905-40a6-9a4e-8a2347298991}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
I don’t know if this says anything about the issues I’ve been having.
Today the issues are:
- Will not skip to next track
- Skips 5-10 first seconds of some tracks, and often skips a few seconds in the middle of tracks
- Tidal and my playlists are suddenly not available anymore after browsing the settings in Audirvana,
they show up on the left side but no tracks are found. - I regularly have to log in to Tidal, loses connection
- Sometimes will not play when I click the play button
I appreciate the new trial period I was given to identify the issues. Hopefully they can be resolved because I really like the sound quality I get from Audirvana.
Another thing;
Sometimes playback stops before end of track.
Also will not automatically continue playing next track in a playlist.
Hi Damien,
it’s a relatively old laptop with 6GB of RAM. Do you think this is a limitation?
I think you should consider contacting Sotm about this issue because we previously had other feedback from users about their device and the UPnP implementation. We will contact them about it on our side but feel free to ask them if they are working on it.
Thanks Damien, I will contact Sotm about the issue. Even better that you are contacting them, to provide the specific information they might need to remedy the issue.
Maybe you could try to re-burn eunhasu on a new sd card … my sms200 Neo is working fine (Audirvana on Mac)
