Exciting News: Public Beta Launch for Audirvāna Android Remote App!
I get a post request error on the show album menuitem. This in on a qobuz track in the search window.
With a low dimmed screen the contrast between grey and purple is very low. I tagged a track as favorite (heart) but could hardly distinguish if it was selected or not.
When will the iOS Remote beta be released? Will it be available as a separate app on the Apple Store? Will it coexist with the current one or overwrite it?
Hi @Ronald_Vergeer , can you please post a screenshot of it?
I see what you mean, it’s part of the things we need to improve. If you go on the light version of the Remtoe app, do you have the same feeling about it? You can change this in the Remote’s appearance settings.
The beta is set to be available next week, if everything goes according to plan.
It will be available through the TestFlight app, but you won’t be able to have the beta and non-beta versions of the Remteo installed, as they have the same name.
I will update the post when it is ready with the information on how to get it :wink:
@Antoine also in the light version with a very far dimmed screen it is hard to see. But i practice i would not dimm the light version that far.
Very interesting. I do get a crash when I search roadhouses in the Remote :sweat_smile:
Can you indicate the OS on which Audirvāna runs and the Android version you use?
I run Audirvana 2.11.6 on a Synology (intel) Nas and have android version 14 on my android tablet. And android 16 on my phone. Both have the same issue.
its something fresh and looking good! I’m sure it will be awesome at release!
Synology nas225+ 6GB - AS 2.99 beta, remote beta
premiÚre impression sur la nouvelle télécommande android , avancée majeure par rapport à la version embryonnaire précédente , merci.
1 - Ă  la sĂ©lection d’un album sur Qobuz, la description apparait subrepticement (1s) puis affichage de la liste des pistes
2- lorsque qu’on visualise un album, le bouton “CrĂ©dit” est placĂ© sur l’image de l’album et donc peu visible :
3 - alĂ©atoirement la lecture se bloque quand on utilise la touche “suivant” ou les temps de rĂ©ponse deviennent trĂšs longs. Cela peut ĂȘtre aussi un saut de 2 pistes d’un coup ou une lecture intermittente de la piste suivante. C’est souvent le cas quand on change de menu pendant la lecture, quand on revient sur le lecteur pour changer de piste cela peu avoir ces effets.
3- j’ai 2 installations (et donc 2 lecteurs rĂ©seau diffĂ©rents). C’est un peu la loterie quand on passe d’une installation Ă  l’autre (mĂȘme en quittant proprement chaque installation). Au dĂ©marrage de l’application, j’accĂšde Ă  la page d’accueil mais quand je sĂ©lectionne un menu (playlist ou favori) ça mouline, il faut fermer l’application et quelquefois arrĂȘter et relancer le package sur le NAS.
Ci dessous un log qui comporte les problÚmes de temps de réponses lors des changements de pistes.
edit : comment vous le transmettre ?
Seeing your picture still can’t see the year album?
Pouvez-vous faire une courte vidéo du problÚme?
Je note votre retour
Est-ce que la lecture aléatoire est activée à ce moment-là ?
Vous avez donc deux NAS?
À l’adresse [email protected]
Android version 14 on my android tablet.
Android 16 on my phone. Both have the same issue.
The hhistory icons on the hometab are not visually refreshed. New tracks are not visually added but when you select the first one it link to (correct) last played track, but uses the wrong image.
It’s somethig we have on our to do list at the moment
A similar thing happens in the favorite tracks screen. You have to click on the track above the one you want.
I lost all my qobuz favorite tracks. The favorite albums are still shown. In qobuz the favorites still exist. A new added favorite is shown.
Can you please send a screenshot of the Remote when you get this? This will help me tell our dev where to fix the issue.
Ce matin j’ai commencĂ© l’écoute au casque bluetooth donc en 44khz mais maintenant que je suis passĂ© sur les enceintes c’est toujours marquĂ© 44khz au lieu de 96khz.
Sur l’app android, sur le mac c’est bon.
C’est pas hyper important mais bon
Ca se met Ă  jour si l’android se met en veille et est rĂ©activĂ©, par contre aprĂšs la rĂ©activation on revient systĂ©matiquement sur l’accueil et pas sur la page ou on Ă©tait avant la mise en veille.
Et des fois page vide:
