Bonjour,
Je possède un DAC TAGA DA-300 .3 usb, et les fichiers DSD ne fonctionnent pas.
Comment résoudre mon problème SVP
J’ai déjà lu les différents sujet, mais je n’ai trouver aucune réponse à mon problème.
Si vous avez une solution, je suis preneur.
Are you using a Mac or a PC? Can you dump the debug info here?
macOS 11.2.2 with 8192MB RAM
Licence enregistrée pour François PERRONE
Per track: OFF
Phase = 52
Max allowed volume: 95.6185
Replay Gain: by track
AUTO: /Volumes/music/Audirvana
Library database path: /Users/francoisperrone/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TAGA Harmony DA-300
Model UID:TAGA Harmony DA-300:262A:9227
UID:AppleUSBAudioEngine:TAGA:TAGA Harmony DA-300:14600000:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 384kHz
Active Sample Rate: 384kHz
Hog Mode is on
ID 0x3a TAGA Harmony DA-300 Manufacturer:TAGA
Model UID:TAGA Harmony DA-300:262A:9227 UID:AppleUSBAudioEngine:TAGA:TAGA Harmony DA-300:14600000:2
32000
Stream ID 0x3b 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Device #0: ID 0x30 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3a TAGA Harmony DA-300 Manufacturer: TAGA Model UID: TAGA Harmony DA-300:262A:9227 UID: AppleUSBAudioEngine:TAGA:TAGA Harmony DA-300:14600000:2
UPnP devices found : 10
Device #0: ID 0x0 Marantz PM7000N UID: uuid:41db768e-3f3a-1bc0-0080-0005cdb7838e Location: http://192.168.0.117:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz SR5012 UID: uuid:f7ce5abb-c728-18e3-0080-0005cdeb3d62 Location: http://192.168.0.100:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Marantz PM7000N UID: uuid:da52347a-6b33-1972-0080-0005cdb7838e Location: http://192.168.0.117:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz PM7000N UID: uuid:20ca8051-3123-1db1-0080-0005cdb7838e Location: http://192.168.0.117:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz PM7000N UID: uuid:81ee9af3-ec86-dc57-5f92-a1bedc2ed933 Location: http://192.168.0.117:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Marantz PM7000N UID: uuid:9a66035a-f890-0858-46bc-755fb9890781 Location: http://192.168.0.117:60006/upnp/desc/aios_device/aios_device.xml
Device #6: ID 0x0 Marantz SR5012 UID: uuid:55ad8cac-9930-1c4d-0080-0005cdeb3d62 Location: http://192.168.0.100:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 Marantz SR5012 UID: uuid:89e7c016-0254-1ae8-0080-0005cdeb3d62 Location: http://192.168.0.100:60006/upnp/desc/aios_device/aios_device.xml
Device #8: ID 0x0 Marantz SR5012 UID: uuid:687ebb09-0b69-89b5-8505-326cc4c8fb8c Location: http://192.168.0.100:60006/upnp/desc/aios_device/aios_device.xml
Device #9: ID 0x0 Marantz SR5012 UID: uuid:79feaee2-a9a2-58c7-fcbf-255b814fa108 Location: http://192.168.0.100:60006/upnp/desc/aios_device/aios_device.xml
Reduce the pre-load cache to 4000MB. Set the NativeDSD method to DoP 1.1.
Merci de la réponse, mais ça ne marche toujours pas.
What do you get? No sound at all? Does it show track advancing?
Le morceau de musique défile, mais il n’y a pas de son.
Try to disable integer mode.
Désoler, mais je ne comprend pas, ou ne voit pas ou désactiver le nombre entier.
Dans quelle rubrique S’il vous plait.
Bonjour,
Je ne suis pas sur la sortie Intégrée, mais sur DAC Taga Harmony DA-300
Merci pour le français, c’est plus facile pour moi.
Pouvez-vous afficher les paramètres que vous avez pour votre TAGA? C’est la partie Capactié de l’appareil qui nous intéresse.
Je suis branché au DAC en USB
What’s the resolution of the file you’re trying to play?
DSD 128, tous les autres formats en KHz passent, sauf les formats DSD
Fichiers achetés à Native DSD, et HDtracks
Pouvez-vous désactiver l’option Format audio natif et refaire un essai?
Désolé, je n’ai pas pu répondre plus tôt car le post était bloqué pendant 4 heures.
Quand je mets les fichiers en conversion PCM, ils fonctionnent.
