The Composer tag is still problematic – Audirvana Studio can only read in the first of multiple composers, like 3.5. However, on some tracks, it has replaced the composer information with multiple composers from it’s own database to display in Audirvana Studio – I could tell by the display format. The program should be made to read in multiple composers from the file tags.
And I don’t appreciate Audirvana Studio using it’s database information instead of my file tag information.
So if I log in to Qobuz and Tidal I see all the duplicates in My Music…
Great job…
Sorry. But there is another app, that really is able to make ONE library with local and streaming services…
Audirvana is not rewriting your tag info in the file. Rather, it can replace the file info with it’s own for display in Audivana (at least for Composer).
I just broke the integer mode (kernel streaming) in Windows. I wasn’t getting DSD output, so I corrected that in the settings. Then I tried to play dsd files and nothing – even got an error message: “Unable to change to integer mode”.
Extremely slow on initial scan of my library. Projected length of initial scan is 6:35. Roon does it in about an hour. I haven’t really played around much with the UI. Waiting for my local library to finish building, first.
Happy to see the launch of Audirvana Studio. My install and initial config went smoothly. It will take some getting used to the new interface, but I expected that based on the pre-release images online.
So far I’m quite pleased with the kernel streaming feature in Windows 10, and the addition of internet radio is well done with sorting by genre, and especially with by sorting by location, or quality. Very nice.
