If you try to use it in real time (playing a track to your computer speakers or a USB output), do you get the same error?
Yes, I can’t get beyond this error message. Passeq won’t function until it activates within Audirvana. All I get is the error message, saying “Error Creating License File”.
Have you take a look at what is said on their website about this error?
Yes, I’ve gone through all of the ‘clues’ on the Plugin Alliance website. But no luck.
I’m certain its not a fault with the plug-ins or their activation, as ALL of my plugins, including other ones from Slate Audio etc, work fine in Garageband.
The problem comes when I try to use them in Audirvana 3.5.50.
So can you please tell me what I can do to solve the issue. Thank you.
