Hello,
I’ve been using Audirvana for a couple of days, mainly with Qobuz, on my Macbook Pro 16" and it was great. The MBP has great sound on its own but I wanted more and bought a DAC.
I bought a Fostex HPA4 and the result is simply unusable.
The reading is (sounds as) twice the speed and a blank every 2 or 3 seconds.
I tried FLAC files on the harddisk and if I use Music from OS X it works, but when back to Audirvana back to hell…
The conf :
MacBook Pro 16" i9 16gigs
Catalina last version
Audirvana last version
Fostex HPA4
Forest USC C to USB B 1,5m cable
I tried to MQA autodetect ON or OFF : no change
Please if someone can solve this I’d be grateful. I was going to buy Audirvana but not in this conditions.
and another symptom concerning Audirvana : even if I selected “Control by keyboard” these are inactive on the Macbook. Don’t know if it is a known issue or an error on my side.
are you on exclusive access in Audirvana DAC preferences.
Do you have another music player on at the same time?
Did you select your dac in midi audio setup for output?
reading back your thing, you said it works with qobuz… so that use internet… then when local it doesn’t work… must be the cable or settings somewhere… don’t you have any regular usb cable to try… i don’t know usb C to B… mine is regular usb connect to usb3 port on mac mini 2012
