Ghost Album Won't Delete
I have a local folder (Portrait In Jazz) and have deleted to try to get one album off my Audirvana.
I have searched for the Album and tracks, doesn’t show up. Only In my Local in Audirvana.
No tracks show up until I put in my favorites. Then only 3. I try to play them, I get a message saying (Unable to Open an Audio File for Playback)
Running a MacMini M2 Pro.
Here Is the Debug Info.
Audirvana Studio 2.6.0 (20600)
macOS 14.1.1 with 16GB physical RAM
Connected account of : Jeffrey White
Sync list: 0 folders
Library database path: /Users/jeffreywhite/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 3105
Listening on 127.0.0.1 on port 49173
Active method: UPnP
Preferred device: [UPnP] AirLens Model UID:PS Audio AirLens UID:uuid:ADFA5F0C-2C29-11EA-8518-985E1B009B3D
Selected device:AirLens
Manufacturer: PS Audio
Model name: AirLens
Model UID: PS Audio AirLens
UID: uuid:ADFA5F0C-2C29-11EA-8518-985E1B009B3D
UPnP device at http://192.168.1.203:38400/description.xml
ID 0x0
Volume control: Yes
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: No
http-get::audio/mpeg:dlna.org_pn=mp3
http-get:
:audio/mpeg:dlna.org_pn=mp3x
http-get::audio/mp4:dlna.org_pn=mp4
http-get:
:audio/mp4:dlna.org_pn=aac_iso_192
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get:
:audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_192
http-get:
:audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get:
:audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmapro
http-get:
:audio/x-ms-wma:dlna.org_pn=wmalsl
http-get::audio/x-sony-oma:dlna.org_pn=atrac3plus
http-get:
:audio/mpeg:*
http-get::audio/l16:
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/x-aac:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsd:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
15 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 0
MediaDuration: 0:03:23
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 AirLens PS Audio http://www.psaudio.com This model is a connected audio module which supports the UPnP/DLNA standard AirLens CDMCM-210-003 uuid:ADFA5F0C-2C29-11EA-8518-985E1B009B3D http://www.psaudio.com DMR-1.50 image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event CDM414006230770 http://192.168.1.203:38400
UPnP devices found : 3
Device #0: ID 0x0 : AirLens
Model name: AirLens
Device #1: ID 0x0 : OPPO BDP-103
UID: uuid:140479c0-58f3-1cef-84bf-6cfdb9d9019b
Manufacturer: OPPO
Model name: OPPO BDP-103
Device #2: ID 0x0 : Denon AVR-X6200W
UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cd681503
Manufacturer: Denon
Model name: *AVR-X6200W
Max. memory for audio buffers: 4416MB
Local Audio Engine: CoreAudio
Device #0: ID 0x32 NT Headless
Manufacturer: @@@
Model UID: 00000000-0000-0000-331D-0103803E2278
Model name: @@@ NT Headless
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
I found an older post and so far, but haven’t added the album back yet seems to be gone.
Hi @Jeffrey1,
It seems you do not have a folder synced with Audirvāna Studio. Can you add the one containing the album you mention?
Hi, I had deleted my synced album in Audirvāna.
I also had removed the album in question and it was the only album still showing up.
That’s when I saw the other post, I apologize for not catching it sooner.
( "Go to User… Home Folder… Library…
Applications Support… Audirvana Folder…
Trash All the files in that folder)
I did this and the ghost album was gone.
Then re-added my local and moved back the album in question and synced for safe measure.
Now it seems to be ok.
I hope I didn’t mess something else up.
Thank you, Jeff
AUTO: /Users/jeffreywhite/Music/For Mac Mini/Audirvana Music
Fingerprinting track 70/1017 : /Users/jeffreywhite/Music/For Mac Mini/Audirvana Music/Bill Evans/Live at Top Of The Gate (Remastered) - 2XHDRE1174/DSD 256fs - 2ch/14. Autumn Leaves DSD 256fs - 2ch.dsf
Listening on 127.0.0.1 on port 49153
Active method: UPnP
Model name: AirLens
ID 0x0
Volume control: Yes
http-get:
http-get:
http-get:
http-get:
http-get:
http-get:
http-get:
:audio/mpeg:*
DLNA 1.5: Yes
15 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:06:29
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Model name: AirLens
Manufacturer: OPPO
Manufacturer: Denon
Manufacturer: @@@
Model UID: Speaker
