Ok, I managed to get the trouser-soiling noise to happen again (as mentioned in my previous post). It seems to occur at random, and seems to be correlated with skipping into a track, but not always ie. I cannot reproduce this by simply skipping forwards. It happens at random (which actually makes it a lot worse). I would consider the noise to be blue-noise like as it seems to have an upward slope as frequency increases (as per my RME ADI-2 display).
This is a pretty serious bug in any music player software - I would imagine that you want a user to trust that the sound that is being sent to their system is pleasant and not literally petrifying. My dogs literally ran out of the room the first time this happened.
Hopefully there is a setting I can use to fix this?
Debug info:
Audirvana Studio 2.6.6 (20606)
macOS Version 13.0 (Build 22A380) with 8GB physical RAM
Connected account of : Jacques Booyens
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Music Effect - MeldaProduction MConvolutionEZ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SW volume control: ON
AUTO: /Users/jacquesbooyens/Library/Mobile Documents/com~apple~CloudDocs/Music/Collection
iTunes/Music library synchronization: last synchronized on Fri Feb 2 17:40:01 2024
Library database path: /Users/jacquesbooyens/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 448
Listening on 127.0.0.1 on port 65351
TIDAL: Connected as HiFi Plus
Active method: UPnP
Preferred device: [UPnP] Living Room Model UID:Linkplay Technology Inc. WiiM Pro-4E82 UID:uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C
Currently playing to UPnP device at 24 bits 88.2kHz
Selected device:Living Room
Manufacturer: Linkplay Technology Inc.
Model name: WiiM Pro-4E82
Model UID: Linkplay Technology Inc. WiiM Pro-4E82
UID: uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C
UPnP device at http://192.168.3.14:49152/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Unhandled (PCM conversion) with boost gain of 0dB
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
http-get::audio/wav:DLNA.ORG_PN=LPCM
http-get::audio/x-wav:DLNA.ORG_PN=LPCM
http-get::audio/mpeg:DLNA.ORG_PN=MP2_MPS
http-get::audio/mp3:
http-get::audio/wma:
http-get::audio/m4a:DLNA.ORG_PN=AAC_ISO
http-get::audio/aac:DLNA.ORG_PN=AAC_ISO
http-get::audio/ac3:DLNA.ORG_PN=AC3
http-get::audio/ogg:*
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:02:55
CurrentURI: http://192.168.3.53:49152/audirvana/audio_f_50.wav
CurrentURIMetadata: <?xml version="1.0"?>
dc:titleMy Mind At Ease</dc:title>
dc:creatorDominique Fils-Aimé</dc:creator>
upnp:artistDominique Fils-Aimé</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/fe9b5e0f/8cd1/4677/a9fe/8a034929371a/640x640.jpg</upnp:albumArtURI>
upnp:albumOur Roots Run Deep</upnp:album>
upnp:originalTrackNumber12</upnp:originalTrackNumber>
song:rate_hz88200</song:rate_hz>
song:format_s24</song:format_s>
song:bitrate4233</song:bitrate>
nextURI: http://192.168.3.53:49152/audirvana/audio_f_51.wav
Feeling Like A Plant
Dominique Fils-Aimé
Dominique Fils-Aimé
Our Roots Run Deep
13
object.item.audioItem.musicTrack
PlayMedium: THIRD-DLNA
Current transport actions:
Stop,Seek,X_DLNA_SeekTime,Pause
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Living Room Linkplay Technology Inc. https://wiimhome.com WiiM Pro Receiver WiiM Pro Receiver https://wiimhome.com uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C V01-Jan 25 2024 00001 WiiM Pro-4E82 FF98F09CC6DBEC21B9CD01F2 QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Living Room Linkplay Technology Inc. https://wiimhome.com WiiM Pro Receiver WiiM Pro Receiver https://wiimhome.com uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C V01-Jan 25 2024 00001 WiiM Pro-4E82 FF98F09CC6DBEC21B9CD01F2 QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1UPnP devices found : 1
Device #0: ID 0x0 : Living Room
Max. memory for audio buffers: 3978MB
Local Audio Engine: CoreAudio
Local devices found : 3
Device #0: ID 0x92 BlackHole 2ch
Manufacturer: Existential Audio Inc.
Model UID: BlackHole2ch_ModelUID
UID: BlackHole2ch_UID
Model name: Existential Audio Inc. BlackHole 2ch
Device #1: ID 0x47 MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x89 ZoomAudioDevice
Manufacturer: zoom.us
Model UID: zoom.us.zoomaudiodevice
UID: zoom.us.zoomaudiodevice.001
Model name: zoom.us ZoomAudioDevice
Chromecast devices found : 1
Device #0: Living Room
Model name: WiiM Pro Receiver
