Mollie?..ā¦
ā¦
You are my hero of this weekā¦ā¦
And iām probably your āthis weeks dumbest personā
you try to convince that audirvana is, what they say it is; all goodā¦
Bitrazer; the dacā¦the dac was the thing you pointed atā¦ And it wasā¦ In a different way you mentioned, but it was the dacā¦ thanks for your help, and my apologiesā¦ but i really really worked hard to find a solution alsoā¦ seriously. ā¦so, thanks again bitrazer.
Damian3, thanks for looking at my thread and trying to help meā¦ Appreciate it muchā¦ thank you, thank you
And Mollieā:crown:ā¦ I think you give me the
answerā:jigsaw:; It was the output on the dac.
I listen multiple times to 1 v , 2v and 3v and decided that the 3v sounds most openā¦no distortion noticed EVER, not even on louder levels. I asked people on forums what the best output is, and mostly, if not all preferred the 3vā¦ So that was also the output i liked mostā¦and choose the 3v output and used it from the beginning when i bought the dac.
Just a minute ago, after reading your remarks i switched to 2vā¦and the humm was less noticableā¦so i switched to 1v, and now it is almost not noticableā¦
And with almost i mean; i notice something in a far,far distanceā¦ And pretty much not noticable.
Soā¦ Iām back being an Audirvanian ā¦ Okay,okayā¦a pretty dumb/annoying Audirvanianā¦ So my apologies to you allā¦and to the software of Audirvana.
Strange it has such an effect on the 16 and 20 bithdeptsā¦ but itās like you said about dsd and amplificationā¦ probably.
I have tube monoblocksā¦ No pre ampā¦
Probably i have to look for a pre amp because the max volume is just enough to drive the sound to a nice power levelā¦maybe just ānotā enough.
If you now an option in audirvana to help this a little it would be greatā¦ Otherwise, itās all good.
AUDIRVANA
PS
And now, i will go stand with my face in the corner for a whileā¦ with some donkey ears on my headā¦
My punishment.
