HiFi ROSE RS150
UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384 - 708 - 768
DSD supported sample rate : 64 - 128 - 256 - 512
DSD Over PCM setting : None
MQA capability : Decoder
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
Playback:
Best upsampling setting for device :
r8brain oversampling DSD512:
bandwidth: 99.5,
stopBandAttenuation: 218,
isPhaseLinear: true
Filter type: B(7th order)
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
Rose RS150b
Nothing is changed. Audirvana doesn’t recognize DSD512, there isn’t option DSD Over PCM: None.
When I play DSD at None: Convert to PCM
Audirvana shows:
Rose RS150b display shows:
When I switched settings to DSD Over PCM 1.1 Audirvana shows:
Where is the problem? There isn’t possibility to play Native DSD.
Regards
There is no problem.
Native DSD can only be played over a Windows ASIO driver (provided by your DAC manufacturer).
All other protocols (WASAPI and Kernel Streaming) can only do DoP (DSD over PCM). If you set your output to ASIO in Audirvana you can do native DSD upto DSD512 (if you have the ASIO driver from Hifi Rose installed).
Maybe you don’t know this, but DSD over PCM (DoP) is also native DSD but ‘disguised’ in a PCM container (to fool the OS). This is recognized by your DAC and restored to DSD again. There are some limitations. In this case with the Hifi Rose the maximum DSD rate over DoP is DSD256 and not DSD512.
These are not limitations of Audirvana and the Hifi Rose, but simply how Windows OS and MacOS work. It does not matter if you are using Audirvana, Roon, JRiver or Foobar etc. These limitations are always the same.
For more info see the links below:
DSD over PCM and DAC max sampling frequency - Audio Formats / DSD - Audirvana
DoP open Standard | DSD-Guide.com
In A+ DSD over PCM standard 1.0 - Software - Audiophile Style
Probably somewhere in here?
Wow. Lots of manuals and info there. Yep probably somewhere in there :wink:
I installed ASIO driver from Rose HiFi and everything looks like below:
Rose playing DSD as WAV. When I had ROON and I played DSD files, Rose shows DSD not WAV. Isn’t the same way playing DSD by Audirvana and ROON? I’m playing over ethernet (UPNP), not by USB.
It makes sense that your Hifi Rose is displaying WAV
In your settings DSD is literally converted to PCM that is not right (and also not the same as DoP or native). You should choose another setting there. I don’t know which options you can choose from, but there should be something like ‘native DSD’ or ‘native’.
But there are certified settings by Audirvana (plays with Audirvana certified). When I try to change manually I have these settings to choose:
When I choose DSD over PCM 1.0 or 1.1 - Rose playing this as WAV 24/176,4kHz :thinking:
Next thing - when I play flac file 24/192 from Qobuz - Rose shows WAV 24/192.
I’ve found this topic:
Enable native DSD over UPnP - Connection with external Audio Devices / UPnP / DLNA - Audirvana
It’s the same problem.
Maybe UPNP has some limitations to passthrough DSD signal. :thinking:
Yes UPnP has a lot of limitations for DSD. I don’t know the max DSD sampling rate for UPnP in this case, but I would not be surprised if it is DSD64 or DSD128 at best.
I thought you where showing me the settings for ASIO. ASIO directly connected via USB is the only way you can play native DSD.
You can only do DoP over UPnP. With UPnP choose ‘DSD over PCM 1.1’. As said you will probably have a limited max DSD samplerate.
Try to connect your Hifi Rose directly via USB to your computer and play through ASIO. As said, that is the only way for native DSD at the full sampling rate (DSD512).
Hi @Basstech,
Since your device is now recognized as PWA, are you using the latest firmware update available for it?
Yes, the device was update and has the latest firmware 4.7.01. Please contact Rose Team in this case, maybe problem is somewhere else.
I will, thanks for the information :slight_smile:
I have been informed by them they will do an update later in October which will fix your issue :wink:
After update Rose RS150b and Audirvana, everything works superb. :ok_hand:
Great, thanks.
Regards
We got the update on our booth at the Paris Audio Video Show on a ROSE unit last Monday :fire:
There is a problem with gapless playback.
When I listen some live albums, there is 1 or 2 second pause between tracks.
Regards
Hi @Basstech,
For Kernel:
Audirvana Studio 2.5.4 (20504)
Windows 10 (19045) with 24GB physical RAM
Connected account of : xxx
Available network interfaces:
Ethernet ({686e6faa-84d1-4d9b-ae3f-06342efd8f8c}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Sync list: 13 folders
AUTO: E:\Audiofile
AUTO: E:\Blues
AUTO: E:\DSF
AUTO: E:\Electronic
AUTO: E:\Hard and Heavy
AUTO: E:\Jazz
AUTO: E:\New Age
AUTO: E:\Polskie
AUTO: E:\Pop
AUTO: E:\Rap
AUTO: E:\Rock
AUTO: E:\Soundtracks
AUTO: E:\Trance
Library database path: C:\Users\skoza\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 9911
Listening on 192.168.1.108 on port 49831
Active method: UPnP
Preferred device: [UPnP] Rose RS150 Model UID:CITECH RS150 UID:uuid:943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6
Currently playing to UPnP device at 24 bits 2822.4kHz
Selected device:Rose RS150
Manufacturer: CITECH
Model name: RS150
Model UID: CITECH RS150
UID: uuid:943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6
UPnP device at http://192.168.1.115:38362/upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/desc
Volume control: Yes
Max volume alert: Disabled
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/m4a:
http-get::audio/aac:
http-get::audio/3gpp:
http-get::audio/amr:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::audio/midi:
http-get::audio/x-midi:
http-get::audio/x-mid:
http-get::audio/x-wav:
http-get::audio/x-ms-wma:
http-get::audio/dsf:
http-get::audio/dsd:
http-get::audio/dff:
http-get::audio/x-dsf:
http-get::audio/x-dsd:
http-get::audio/x-dff:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (0dB to 0dB)
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
NrTracks: 1
MediaDuration: 00:04:46
CurrentURI: http://192.168.1.108:49152/audirvana/audio_f_25.dff
CurrentURIMetadata:
dc:titlePlanet Of Visions</dc:title>
dc:creatorKraftwerk</dc:creator>
upnp:artistKraftwerk</upnp:artist>
upnp:genreElectronic</upnp:genre>
upnp:albumArtURIhttp://192.168.1.108:49152/audirvana/artwork_1_25.jpg</upnp:albumArtURI>
upnp:albumMinimum - Maximum (DSD64)</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Stop,Pause,Seek
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Rose RS150 CITECH HiFi ROSE RS150 1 http://4thline.org/projects/cling/mediarenderer/ uuid:943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6 DMR-1.50 av-upload,image-upload,audio-upload image/png 48 48 32 /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/msi.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/desc /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/action /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/desc /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/action /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/desc /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/action /upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/event
Device #1: Rose RS150
	Location: http://192.168.1.115:38362/upnp/dev/943b5cb7-f1ee-9dfe-ffff-ffffc0860aa6/desc
	Model name: RS150
Max. memory for audio buffers: 9942MB
Device #0: SAMSUNG (2 — Audio dla wyświetlaczy Intel(R))
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_2809&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d839b7c6-c3b6-46e5-8053-ac60fc41af84}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 4
Device #0: Home Hub
Model name: Google Nest Hub
Device #1: Home Mini
Model name: Google Home Mini
Device #2: Harman
Model name: HK Citation One
Device #3: Google Home
For ASIO:
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
AUTO: E:\Audiofile
AUTO: E:\Blues
AUTO: E:\DSF
AUTO: E:\Electronic
AUTO: E:\Jazz
AUTO: E:\New Age
AUTO: E:\Polskie
AUTO: E:\Pop
AUTO: E:\Rap
AUTO: E:\Rock
AUTO: E:\Trance
Active method: UPnP
Model name: RS150
Volume control: Yes
DLNA 1.5: Yes
NrTracks: 1
MediaDuration: 00:04:22
CurrentURI: http://192.168.1.108:49152/audirvana/audio_f_31.dff
CurrentURIMetadata:
dc:titleTour De France Etape 1</dc:title>
upnp:albumArtURIhttp://192.168.1.108:49152/audirvana/artwork_0_31.jpg</upnp:albumArtURI>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Stop,Pause,Seek
UPnP devices found : 2
	Model name: RS150
Local Audio Engine: ASIO -2147478866
Driver version 10019
Device #0: CITECH USB Audio Device
Manufacturer:
Model UID: CITECH USB Audio Device
Model name: CITECH USB Audio Device
Device #0: Home Hub
Device #2: Harman
When I play DSD - gapless never works. Everything else from Tidal, Qobuz or local files except DSD works properly.
I see, so gapless with PCM is working properly but not with DSD, can you contact them about this manner and check if they get the same behavior on their end? I do not have the unit here at the office so I can’t reproduce this on my side :frowning:
