You’ve gone into the DAC settings? You need to post up your debug and setup details so that we might understand what’s happening.
Is that recording in 5 channels? Looks like your file is in 5. channels not 2 channel
Oddly HRA doesn’t show a 5.1 mix for this album but does show her other albums in surround sound on SACD.
Thanks for response. Give you another same sample which has stereo and 6 CH. But it only displays the 6 CH. playing list in Audirvana, in which there are only 3 tracks. How can I switch to display the stereo track list?
(p.s. the popup white window is another application to show the ISO contents.)
6 CH. has 3 tracks; stereo has 11. But only show 6 CH. track in Audirvana. why?
Audirvana Studio 2.2.3 (20203)
macOS Version 13.1 (Build 22C65) with 16GB physical RAM
Connected account of : alon CHENG
Sync list: 4 folders
AUTO: /Volumes/SACD/爵士/绫户智绘:Chie Ayado/绫户智绘:Chie Ayado - SEVEN 【DSF】
AUTO: /Volumes/SACD/爵士/绫户智绘:Chie Ayado/绫户智绘:Chie Ayado - To You SACD
AUTO: /Volumes/SACD/爵士/绫户智绘:Chie Ayado/绫户智绘:Chie Ayado - 爱的琴韵FIFTY 50 Chie Ayado - fifty SACD
AUTO: /Volumes/SACD/爵士/绫户智绘:Chie Ayado/绫户智绘:Chie Ayado - 美好时光Time Hybrid SACD
Library database path: /Users/alon/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53926
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
SENNHEISER SENNHEISER USB 2.0 Audio Out
Model UID:SENNHEISER USB Audio 2.0:1377:4000
UID:AppleUSBAudioEngine:SENNHEISER :SENNHEISER USB Audio 2.0:1-028982FD40151:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:SENNHEISER USB 2.0 Audio Out
Manufacturer: SENNHEISER
Model name: SENNHEISER USB 2.0 Audio Out
Model UID: SENNHEISER USB Audio 2.0:1377:4000
UID: AppleUSBAudioEngine:SENNHEISER :SENNHEISER USB Audio 2.0:1-028982FD40151:1
USB Vendor ID: 0x1377
USB Product ID: 0x4000
ID 0x8e
Audio buffer frame size : 53 to 4096 frames
Stream ID 0x8f 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x8e SENNHEISER USB 2.0 Audio Out
Device #1: ID 0x43 MacBook Air扬声器
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Air扬声器
Hello @alon , I wanted to get the ball rolling for you. I’m not well enough versed in SACD ripping and the proper metadata etc. Here’s one I found with a quick search, hopefully we get some more feedback from the community. How did you rip the disks, what format? How have you edited their metadata? Do some more digging with the search engine as I know that some of these questions have already been asked and solved previously
Hey @OffRode , appreciate your sharing. Yes, it looks we both have the same request to
place an easily accessible switch/choice to set Audirvana to filter only on stereo | 5 CH. | 6 CH. | etc. | all together?
though we have different scenarios.
My temporary solution is to remove the multi-channel tracks in ISO via a third-party tool. Then Audirvana can identify the stereo tracks which are remained. Meanwhile I can also update the metadata via the same tool.
@alon@OffRode … It makes perfect sense that you would need to separate .dsf or .dst files for both the 2-channel and 5.1 multi-channel areas of the .iso file… I extract the stereo and the 5.1 areas as separate folders… I have created a new topic in the Lounge for those that are ripping their personal library of SACDs: Ripped or Ripping SACDs?https://community.audirvana.com/t/ripped-or-ripping-sacds/36254
is the actual sample rate and channel of the track you have in this folder. This does not mean however that it will play at DSD 64 5ch unless you have a DAC that can do so. If you play this track to a Stereo device (like the one you selected), it won’t play the file on 5 channel but Stereo.
Hi @Antoine , I guess you don’t catch my point. Let me try to reclarify. #1 My SACD-ISO have 2 types of channel tracks (stereo + 6 CH.) #2 Audirvana has only showed 6 CH. tracks (Yes, it plays in stereo even the tracks in 6 CH.) #3 how can I see my stereo tracks? Sometimes the tracks in stereo and 5 ch. are different. like this one. In this case, it means I can only play 3 tracks in 6 ch., no 11 tracks in stereo.
So my question is how to switch to stereo tracks list in Audirvana and play stereo tracks?
I think I better understand what you need, when you are in your album, you can add columns to it. If you add the number of Audio Channels, you should now be able to differentiate your Stereo and Multichannel tracks.
