I’ve been having various issues with the beta, including a failed install, so wondering if its a good idea for troubleshooting purposes to completely uninstall the beta, and reinstall.
Are there specific instructions on how to uninstall the beta and all the folders and setting files? (I’m more of a mac user - forgive me if its an obvious answer!)
Just use the standard Windows way: in Settings, Programs & Features, uninstall Audirvana Plus.
You can also remove the database file located in c:\users[your user name]\AppData\Local\Audirvana\Audirvana Plus
