Hi,
I’m playing an audio file that consistently pops at the same loud passages while playing on Audirvana w/Integer Mode On. This happens on both FLAC and AIFF formats of the same audio clip.
This doesn’t happen when I turn off Integer Mode.
Mac Mini (Late 2012 - 10.15.5)
Connected via USB to Schiit Audio Bifrost (1st Gen) connected to Integrated Amplifer and then speakers.
This does not happen when playing the same file in VLC or Audacity - USB - DAC- AMP
macOS 10.15.5 with 16384MB RAM
Per track: OFF
Max allowed volume: 94.3893
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/mediaplayer/My Music/Music/HD Music
AUTO: /Users/mediaplayer/My Music/Music/Music
Library database path: /Users/mediaplayer/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1768MB
Speaker-Schiit USB Audio Device
Model UID:Schiit USB Audio Device:0D8C:0319
UID:AppleUSBAudioEngine:Schiit:Schiit USB Audio Device:14200000:1
Sample rate switching latency: 1s
ID 0x29 Speaker-Schiit USB Audio Device Manufacturer:Schiit
Model UID:Schiit USB Audio Device:0D8C:0319 UID:AppleUSBAudioEngine:Schiit:Schiit USB Audio Device:14200000:1
24 virtual formats:
36 physical formats
Local devices found : 3
Device #0: ID 0x36 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3d HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-F303-01010101}
Device #2: ID 0x29 Speaker-Schiit USB Audio Device Manufacturer: Schiit Model UID: Schiit USB Audio Device:0D8C:0319 UID: AppleUSBAudioEngine:Schiit:Schiit USB Audio Device:14200000:1
