Integer mode stopped working on the latest Mac OS Tahoe when I installed the public beta when it was released. There was faint distortion during playback that was only audible when I turn the volume all the way up. I was hoping the problem would go away with the official release of Mac OS Tahoe 26.0, but the problem still remains. Playback is fine with integer mode turned off.
I read some of the older posts saying that integer mode doesn’t really work on Macs due to Apple blocking access to the kernel (or something along those lines) – is this still the case?
Audirvana Origin 2.6.2 (20602)
Running on MacBook Pro (13-inch, M1, 2020), Apple M1
macOS Version 26.0 (Build 25A354) ARM64 with 16GB physical RAM
Connected account of : Hadi Mahmud
Local network access: allowed
LOADING/DECODING:
Max audio buffer size: 13312MB
Effect Plugins: NOT ACTIVE
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/hadimahmud/Music/DJ MIXES/DJ Sets
AUTO: /Users/hadimahmud/Music/LOSSLESS
Sync folders at startup: YES
Sort and display order: en_US
Library database path: /Users/hadimahmud/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on
en0 IPv4: 192.168.101.15
on port 49277
Font size: regular
Library
My Music
Startup view: Last displayed view
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Built-in Output
Model UID:
UID:
Selected device:SMSL USB AUDIO
Manufacturer: SMSL
Model name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:1100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
ID 0x5f
MQA Decoder device
Stream ID 0x60 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x5f SMSL USB AUDIO
Manufacturer: SMSL
Device #1: ID 0x53 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #2: ID 0x4d Serato Virtual Audio
Manufacturer: Serato
Model UID: VirtualAudio_ModelUID
UID: VirtualAudio_UID
Model name: Serato Virtual Audio
Wi-Fi
