Integer mode not working on MacOS Tahoe (no sound during playback)
We have been able to reproduce the issue. As we speak, there have been some changes in the core audio of the latest macOS version, given the problem encountered by third-party apps like ours.
In the case of the Meridian, and probably a lot of the devices having the issue (like the SMSL), we can see this:
In Tahoe:
In Sequoia:
This indicates changes made by Apple in the driver, and in such a manner, we will try our best to do a fix for it.
However, please keep in mind that this issue will need to be addressed by Apple, hopefully very soon.
Perhaps this information helps.
Since I installed Tahoe, I experience a heavily (not just slightly) distorted sound when playing back an audio file with Audirvana Origin 2.6.2 (20602) on a Mac Mini with an Apple M2 chip and Integer mode On. When I switch Integer Mode toOff, it plays again.
With good old Audirvana 3.5.50 (I still use it for I love the way I can easily modify tags simultaneously for many files) same file is played well with 'Optimize system for playback On
Same here with me. Latest Audirvana studio (please find system/playback data below) won’t playback any DSD files with “Integer mode = On” anymore on MacOS 26 Tahoe (@ThijsA : Thanks for the tip above! - did not get this to work before…)
Audirvana Studio 2.11.3 (21103)
Running on Mac mini (2023), Apple M2
macOS Version 26.0 (Build 25A354) ARM64 with 16GB physical RAM
Connected account of : R***** T*****g
Local network access: allowed
LOADING/DECODING:
Max audio buffer size: 11160MB
Internal EQ: OFF
Effect Plugins: NOT ACTIVE
Bandwidth at 0dB = 99.5%
Phase = 49%
Replay Gain: by track
AUTO: /Volumes/Musik/
Sync folders at startup: YES
Sort and display order: de
Library database path: /Users/thaetig/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 10033
Listening on
en1 IPv6: fd6e:3f0b:2ea2:7d4d:1c75:e608:94d3:8d65
en1 IPv4: 192.168.0.11
on port 49234
TIDAL: Connected as PREMIUM
Font size: regular
Language: Systemsprache
Lokal
Meine Musik
Streaming
Radios
Podcasts
Startup view: Lokale Bibliothek: Alben
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 11160MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: OFF
Actual I/O buffer frame size: 4096
Hegel Music Systems Hegel H390 USB
Model UID:Hegel H390 USB:20B1:30CF
UID:AppleUSBAudioEngine:Hegel Music Systems:Hegel H390 USB:110000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Sample rate switching latency: 1s
Selected device:Hegel H390 USB
Manufacturer: Hegel Music Systems
Model name: Hegel Music Systems Hegel H390 USB
Model UID: Hegel H390 USB:20B1:30CF
UID: AppleUSBAudioEngine:Hegel Music Systems:Hegel H390 USB:110000:1
USB Vendor ID: 0x20b1
USB Product ID: 0x30cf
ID 0x96
Max volume alert: Disabled
MQA Decoder device
DSD via PCM 1.1
Stream ID 0x97 2 channels starting at 1
40 virtual formats:
60 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 4
Device #0: ID 0x83 SONY TV *00
Manufacturer: SNY
Model UID: 4DD903F9-0000-0000-011B-0103806C3D78
Model name: SNY SONY TV *00
Device #1: ID 0x96 Hegel H390 USB
Device #2: ID 0x5d Mac mini-Lautsprecher
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac mini-Lautsprecher
Device #3: ID 0x43 Multiausgangsgerät
Model UID: ~:AMS2_StackedOutput:0
Model name: Apple Inc. Multiausgangsgerät
WLAN
UPnP devices found : 4
Device #0: ID 0x0 : BRAVIA4KGB-94[DLNA]
UID: uuid:4d9d881c-b822-4fef-9e78-ca5e6e8bd257
Manufacturer: SoftMedia Inc.
Model name: AirReceiver
Device #1: ID 0x0 : KD-49XD8005
UID: uuid:23456789-1234-1010-8000-104FA8CBC359
Manufacturer: Sony Corporation
Model name: MediaRenderer
Device #2: ID 0x0 : 48OLED935/12
UID: uuid:F00DBABE-AA5E-BABA-DADA-8641E1571CE1
Manufacturer: Philips
Model name: Philips TV DMR
Device #3: ID 0x0 : Hegel-H390
UID: uuid:6163d4c2-1dd2-11b2-a3ea-8f522eaff9ab
Manufacturer: Hegel
Model name: H390
Chromecast devices found : 2
Device #0: KD-49XD8005
Model name: BRAVIA 4K GB
Device #1: 48OLED935/12
Model name: TPM191E
I’m using a Mac Mini M2 with only Audirvana Origin 2.6.2 and macOS Tahoe, no other programs.
I use FLAC and DSD files and haven’t noticed any problems.
I upsample all my FLAC files to DXD.
Havn’t used Origin for a few weeks. Since then, installed Tahoe but Origin sees nothing to play. Files are in a folder on Desktop. Have tried deleting app and re-installing. Also Shut Down. Help! Audirvava Origin is a brick.
Interesting quote from forum on the Tahoe beta in relation to beta 8. If correct may explain why my Chord Dacs and KEF LS50’s WII work as they are 32 bit capable (The KEFS only when networked) Same issue with integer mode reported on J River forum……
“Still not fixed Core Audio Integer Mode forcing 32 bit float even if the DAC doesn’t support it and wants 16 or 24 bit integer. Exclusive audio was one of the main reasons I am dailying a mac instead of a windows pc, and now that feature is partially broken.”
Wondering why Audirvana 3.5 might still work on Tahoe through the same DAC, but not Studio. As another poster reported, the old Audirvana works with full system optimisation and in integer mode. How could this be when both versions interact with the same CoreAudio code?
Good point but the issue is impacting users of J River also with integer mode not working so has to be a core audio/DAC issue as it is not specific to AS/AO alone. Audirvana keep their IP well guarded so only they could be able to understand the differing experience with 3.5 and AS/AO. I’m sure they will enlighten us of the root cause soon enough………
Still waiting to hear from Audirvana, especially as I cannot stream Presto hi-res through Audirvana 3.5.x. If you’re monitoring, please fix!
Audirvana 3.5 is not supported from a long time now…
don’t get too much hope :slight_smile:
The thing i am thinking is why the old version still has better feature still working from Origin or Studio? even the remote is better on old version, and it was not even good then :slight_smile:
Audirvana 3.5 was an absolutely superb piece of software, designed by a Mac lover, who’s moved on to allegedly greener pastures.
For those that do not have the issue on the 3.5, can you please post your debug info ?
Running on MacBook Pro (16-inch, 2021), Apple M1 Pro
Connected account of : A P David
LOADING/DECODING:
Max audio buffer size: 3002MB
Per track: OFF
Internal EQ: OFF
Sync list: 3 folders
AUTO: /Volumes/Muse/DSD FLAC
AUTO: /Volumes/Muse/Music/Music
AUTO: /Volumes/Muse/SACD iso
Sort and display order: en
Library database path: /Users/amirthanayagamdavid/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 19667
Listening on
en7 IPv6: fda0:74d3:4483:db4a:87e:c7a1:4d38:876
en7 IPv6: 2600:8800:e08e:6800:1881:9688:2284:8cb1
en7 IPv4: 192.168.0.114
en7 IPv6: 2600:8800:e08e:6800::e011
on port 61050
Font size: regular
My Music
Streaming
Radios
Podcasts
Startup view: Last displayed view
Number of paired remotes: 2
Max. memory for audio buffers: 3002MB
Integer mode: ON
Holo Audio Holo Audio UAC2.0 Gen2 Enhanced
Model UID:Holo Audio UAC2.0 Gen2 Enhanced:152A:87C0
UID:AppleUSBAudioEngine:Holo Audio:Holo Audio UAC2.0 Gen2 Enhanced:2110000:1
Selected device:Holo Audio UAC2.0 Gen2 Enhanced
Manufacturer: Holo Audio
Model name: Holo Audio UAC2.0 Gen2 Enhanced
Model UID: Holo Audio UAC2.0 Gen2 Enhanced:152A:87C0
UID: AppleUSBAudioEngine:Holo Audio:Holo Audio UAC2.0 Gen2 Enhanced:2110000:1
USB Vendor ID: 0x152a
USB Product ID: 0x87c0
ID 0x59
12 available sample rates up to 1536000Hz
1411200
1536000
DSD via PCM 1.1
Stream ID 0x5a 2 channels starting at 1
36 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 1536kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 1411.2kHz
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 1536kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 1411.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 1411.2kHz
Local devices found : 3
Device #0: ID 0x63 32S327
Manufacturer: TCL
Model UID: 506C0000-0000-0000-301E-010380472878
Model name: TCL 32S327
Device #1: ID 0x59 Holo Audio UAC2.0 Gen2 Enhanced
Device #2: ID 0x4b MacBook Pro Speakers
Model UID: Speaker
Selected Network interface: USB 10/100/1000 LAN
USB 10/100/1000 LAN
Chromecast devices found : 1
Device #0: Telemachus TV
Model name: Smart TV Pro
Please note that my Mytek Brooklyn DAC+ is not recognized by macOS Tahoe (thus Audirvana also). My Mac Studio is connected via USB to Brooklyn DAC+ as well as MUTEC MC-3+USB (which sends reclocked digital data to Brooklyn DAC+ via AES/EBU).
Running on Mac Studio, Apple M1 Max
macOS Version 26.0 (Build 25A354) ARM64 with 64GB physical RAM
Connected account of : Kohji Matsubayashi
LOADING/DECODING:
	Max audio buffer size: 25964MB
	Sync list: 2 folders
		AUTO: /Volumes/Music/iTunes Media/Music
		AUTO: /Volumes/Music/others
	Library database path: /Users/shaolin/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
	/Volumes/Music/iTunes Media/Music/Punkt.Vrt.Plastik/Somit
	Deep Synch: no
	Scanning 5/13: /Volumes/Music/iTunes Media/Music/Punkt.Vrt.Plastik/Somit/04 Natt Raum.m4a
	Listening on
		en0 IPv4: 192.168.0.13
		en0 IPv6: 2409:10:8340:3d10:c76:b9cd:cb57:e784
	 on port 57032
	Font size: large
		My Music
		Library
	Startup view: Library: Albums
	Use media keys: no
	Use Apple Remote: no
	Screen saver disabled: no
Max. memory for audio buffers: 25964MB
	Integer mode: ON
	MUTEC GmbH MC-3+ Smart Clock USB 2.0
	Model UID:MC-3+ Smart Clock USB 2.0:29A2:0086
	UID:AppleUSBAudioEngine:MUTEC GmbH:MC-3+ Smart Clock USB 2.0:8341100:1,2
	Sample rate switching latency: 1.5s
	Limit bitdepth to 24bit: ON
Selected device:MC-3+ Smart Clock USB 2.0
	Manufacturer: MUTEC GmbH
	Model name: MUTEC GmbH MC-3+ Smart Clock USB 2.0
	Model UID: MC-3+ Smart Clock USB 2.0:29A2:0086
	UID: AppleUSBAudioEngine:MUTEC GmbH:MC-3+ Smart Clock USB 2.0:8341100:1,2
	USB Vendor ID: 0x29a2
	USB Product ID: 0x0086
	ID 0xa9
7 available sample rates up to 352800Hz
Stream ID 0xaa 2 channels starting at 1
21 virtual formats:
28 physical formats
Local devices found : 14
	Device #0: ID 0xba LG Ultra HD
		Manufacturer: GSM
		Model UID: 1E6D095B-0000-0000-031D-0104B53C2278
		Model name: GSM LG Ultra HD
	Device #1: ID 0x9f Yeti Stereo Microphone
		Manufacturer: Generic
		Model UID: Yeti Stereo Microphone:046D:0AB7
		UID: AppleUSBAudioEngine:Generic:Blue Microphones:LT_200918043411D70F047F_111000:2
		USB Vendor ID: 0x046d
		USB Product ID: 0x0ab7
		Model name: Generic Yeti Stereo Microphone
	Device #2: ID 0xa9 MC-3+ Smart Clock USB 2.0
	Device #3: ID 0x40 BlackHole 2ch
		Manufacturer: Existential Audio Inc.
		Model UID: BlackHole2ch_ModelUID
		UID: BlackHole2ch_UID
		Model name: Existential Audio Inc. BlackHole 2ch
	Device #4: ID 0x8a Mac Studio Speakers
		Model UID: Speaker
		Model name: Apple Inc. Mac Studio Speakers
	Device #5: ID 0x68 Microsoft Teams Audio
		Manufacturer: Microsoft Corp.
	Device #6: ID 0x7e Pro Tools Audio Bridge 16
		Manufacturer: Avid
		Model UID: ProToolsAudioBridge_ModelUID
		UID: Pro Tools Audio Bridge 16_UID
		Model name: Avid Pro Tools Audio Bridge 16
	Device #7: ID 0x72 Pro Tools Audio Bridge 2-A
		Manufacturer: Avid
		UID: Pro Tools Audio Bridge 2-A_UID
		Model name: Avid Pro Tools Audio Bridge 2-A
	Device #8: ID 0x76 Pro Tools Audio Bridge 2-B
		Manufacturer: Avid
		UID: Pro Tools Audio Bridge 2-B_UID
		Model name: Avid Pro Tools Audio Bridge 2-B
	Device #9: ID 0x82 Pro Tools Audio Bridge 32
		Manufacturer: Avid
		UID: Pro Tools Audio Bridge 32_UID
		Model name: Avid Pro Tools Audio Bridge 32
	Device #10: ID 0x86 Pro Tools Audio Bridge 64
		Manufacturer: Avid
		UID: Pro Tools Audio Bridge 64_UID
		Model name: Avid Pro Tools Audio Bridge 64
	Device #11: ID 0x7a Pro Tools Audio Bridge 6
		Manufacturer: Avid
		UID: Pro Tools Audio Bridge 6_UID
	Device #12: ID 0x3d Pro Tools Aggregate I/O
		Model UID: com.Avid.ProToolsAnalogIOAggregateDevice
		Model name: Apple Inc. Pro Tools Aggregate I/O
	Device #13: ID 0x90 ZoomAudioDevice
		Manufacturer: zoom.us
		Model UID: zoom.us.zoomaudiodevice
		UID: zoom.us.zoomaudiodevice.001
		Model name: zoom.us ZoomAudioDevice
		Ethernet
… and below is the debug output for Audirvana 3.5.50:
macOS 26.0.0 with 65536MB RAM
Registered to Kohji Matsubayashi
	iTunes/Music library synchronization: last synchronized on Mon Jun  7 10:39:58 2021
	Library database path: /Users/shaolin/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
	Qobuz:  Connected as Qobuz Studio
Max. memory for audio buffers: 20494MB
	ID 0xa9 MC-3+ Smart Clock USB 2.0	Manufacturer:MUTEC GmbH
	Model UID:MC-3+ Smart Clock USB 2.0:29A2:0086	UID:AppleUSBAudioEngine:MUTEC GmbH:MC-3+ Smart Clock USB 2.0:8341100:1,2
21 virtual formats:
	2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
28 physical formats
	2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Device #0: ID 0xba LG Ultra HD	Manufacturer: GSM	Model UID: 1E6D095B-0000-0000-031D-0104B53C2278	UID: 1E6D095B-0000-0000-031D-0104B53C2278
Device #1: ID 0x9f Yeti Stereo Microphone	Manufacturer: Generic	Model UID: Yeti Stereo Microphone:046D:0AB7	UID: AppleUSBAudioEngine:Generic:Blue Microphones:LT_200918043411D70F047F_111000:2
Device #2: ID 0xa9 MC-3+ Smart Clock USB 2.0	Manufacturer: MUTEC GmbH	Model UID: MC-3+ Smart Clock USB 2.0:29A2:0086	UID: AppleUSBAudioEngine:MUTEC GmbH:MC-3+ Smart Clock USB 2.0:8341100:1,2
Device #3: ID 0x40 BlackHole 2ch	Manufacturer: Existential Audio Inc.	Model UID: BlackHole2ch_ModelUID	UID: BlackHole2ch_UID
Device #4: ID 0x8a Mac Studio Speakers	Manufacturer: Apple Inc.	Model UID: Speaker	UID: BuiltInSpeakerDevice
Device #5: ID 0x68 Microsoft Teams Audio	Manufacturer: Microsoft Corp.	Model UID: MSLoopbackDriverDevice_ModelUID	UID: MSLoopbackDriverDevice_UID
Device #6: ID 0x7e Pro Tools Audio Bridge 16	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 16_UID
Device #7: ID 0x72 Pro Tools Audio Bridge 2-A	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 2-A_UID
Device #8: ID 0x76 Pro Tools Audio Bridge 2-B	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 2-B_UID
Device #9: ID 0x82 Pro Tools Audio Bridge 32	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 32_UID
Device #10: ID 0x86 Pro Tools Audio Bridge 64	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 64_UID
Device #11: ID 0x7a Pro Tools Audio Bridge 6	Manufacturer: Avid	Model UID: ProToolsAudioBridge_ModelUID	UID: Pro Tools Audio Bridge 6_UID
Device #12: ID 0x3d Pro Tools Aggregate I/O	Manufacturer: Apple Inc.	Model UID: com.Avid.ProToolsAnalogIOAggregateDevice	UID: com.Avid.ProToolsAnalogIOAggregateDevice
Device #13: ID 0x90 ZoomAudioDevice	Manufacturer: zoom.us	Model UID: zoom.us.zoomaudiodevice	UID: zoom.us.zoomaudiodevice.001
Thanks, very interesting, we will investigate more about this and report back once we have something to share.
+1
BTW, also HQPlayer had to fix the Tahoe coreaudio issue.
I have this issue as well. Had me panicking for a moment.
I use a headless Mac mini and had to go and dig out keyboards/cables etc. because the update turned FileVault back on so no more automatic login.
Just wanted to say that I’m having the same issue running Audirvana Origin 2.6.2 on a 2022 Mac Studio (M1 Max chip) after upgrading to Tahoe 26.0. With Integer Mode on, playback is distorted. With Integer Mode off, playback is normal. Thank you for working on this.
Here’s the detailed update of my experiments:
I found out that, at least in my environment (mac Studio M1 Max to MC-3+USB to Brooklyn DAC+), Audirvana Origin plays smooth even with “Exclusive Access” and “Integer Mode” both on, ONLY WHEN the music is 16/44.1 format.
No other formats (24/44.1, 24/48, or any other formats above it) can be played with Audirvana Origin with Integer Mode ON (more precisely, the UI shows it is played fine, but no sound from the DDC/DAC).
Even if I manually align the “Input Format” in Audio MIDI Setup for the DDC, the playback is completely muted. But only with the 16/44.1 files can be played fine.
As for the Origin’s “Music Integrated Mode”, it is completely unusable: when both “Exclusive Access” and “Integer Mode” on, both the Music app and Audirvana Origin app becomes “Not Responding” (on Activity Monitor); when “Integer Mode” off, it plays somehow, but never-ending quick starts/stops automatically happen, thus totally unlistenable.
Finally with a good ol’ Audirvana 3.5, it plays fine, local ALAC files and Qobuz streaming – even with Integer Mode on, and various formats from 16/44.1 to 24/192. Its “Music Integrated Mode” is the only exception, becoming “Not Responding” again.
