After installing Tahoe, I can’t output DSD (DoP) files to my Gustard X30 DAC, Audievana plays but no sound come through - but PCM files work fine. I have the lastest Origin update on a Mac Mini M1. Does anyone know how to fix that - or do we wait for Audirvana/Apple bug fixing?
Hello,
I updated my Mac mini to Mac OS Tahoe 26.0 and after that Audirvāna does not play music anymore besides 16/44,1khz.
I only stream from Qobuz and upto the most recent update all was well.
Is this problem already known and taken care of or??
Thanx in advance for the help
Dolf
Audirvana Studio 2.11.3 (21103)
Running on Mac mini (M1, 2020), Apple M1
macOS Version 26.0 (Build 25A354) ARM64 with 8GB physical RAM
Hi @Dolf,
There is already a thread about this subject (searching this forum is your friend):
Integer mode not working on MacOS Tahoe (no sound during playback) - Origin - Audirvana
@Antoine may I ask you to merge this post with the already existing one(s)?
Hello Andy @ Antoine
Thanx for your efforts and I will follow this issue further in the other thread in the Origin section.
I hope the solution will follow a.s.a.p!!
D
Hi @Dolf, I hope so too.
It seems to be a problem in Tahoe that does not only affect Audirvana, but other players too. JRiver seems to have the same problem also and in the Roon forum I saw some posts popping up as well. I hope this bug gets fixed (by Apple or Audirvana).
Anyway, I will stop posting in this thread and watch the other one. Have a nice evening!
I have the same issue. Thanks.
That’s interesting. I’m having a different experience. Even 16-bit/44.1 kHz PCM FLAC plays with blippy distortion in my setup. Playback becomes normal only when I turn off Integer Mode.
Alright, guys, can you please try this version of Audirvāna Studio/Audirvāna Origin?
https://audirvana-my.sharepoint.com/:f:/p/antoine/EhLwOG2lkb5MtG-Lb9oOtA0BPdbPKOHSwyV2qgwvmIdWVg
Bingo! Thank you.
I confirmed that the Audirvāna Origin 2.6.2.99 plays tracks with any resolutions nicely on my environment, with Exclusive Access and Integer Mode ON. Thank you.
The only regret is that Music Integrated Mode is still not compatible with Tahoe: never-ending quick start/stop keeps going, even with Exclusive Acceess and/or Integer Mode OFF.
EDIT: I could finally managed to make the Music Integrated Mode temporarily working, even with Exclusive Access and Integer Mode ON. But only one file: on next track the quick-start/stop starts again. Force-killing the coreaudiod process sometimes fix it, but not always.
Interestingly, I didn’t experience any issues after updating my Mac Mini M2.
DSD and FLAC files work normally.
Is this because I’m upsampling the FLAC files to DXD?
Integer Mode plays normally now! Thank you.
Good morning Antoine,
Thank you for the quick solution. After updating to version 2.11.4, everything works as usual again.
I face this issue again. please suggest me any solution.
Thank you for solving the problem so fast ![]()
Hi @abdullah95 , have you installed the latest version of Audirvāna Origin/Audirvāna Studio?
I just wanna say that you just Make sure exclusive access and integer mode are turned on. I think by turning this your problem get solve.
