Hello,
Please see below for the debug info.
Thank you,
Audirvana Origin 2.5.13 (20513)
macOS Version 14.5 (Build 23F79) with 16GB physical RAM
Connected account of : Yusuke Tanaka
Per track: OFF
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Jan 31 00:37:26 2024
Library database path: /Users/tankorolin/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49165
Font size: regular
My Music
Library
Use Apple Remote: no
Number of paired remotes: 2
Screen saver disabled: no
Max. memory for audio buffers: 12212MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
XMOS HIFI DSD
Model UID:HIFI DSD:20B1:0008
UID:AppleUSBAudioEngine:XMOS :HIFI DSD:2300000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:HIFI DSD
Manufacturer: XMOS
Model name: XMOS HIFI DSD
Model UID: HIFI DSD:20B1:0008
UID: AppleUSBAudioEngine:XMOS :HIFI DSD:2300000:1
USB Vendor ID: 0x20b1
USB Product ID: 0x0008
ID 0x32
Max volume alert: Disabled
Stream ID 0x33 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0xd4 RX-A800
Manufacturer: YMH
Model UID: 65A85631-0000-0000-0014-010380000078
Model name: YMH RX-A800
Device #1: ID 0x32 HIFI DSD
Manufacturer: XMOS
Device #2: ID 0x62 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 : Bedroom
UID: uuid:FF970010-CE84-F88E-779C-A5BDFF970010
Manufacturer: Belkin International Inc.
Model name: SOUNDFORM CONNECT
Chromecast devices found : 2
Device #0: Bedroom Chromecast
Model name: Chromecast Ultra
Device #1: Living room display
Model name: Google Nest Hub
