@organm ā¦Iām a headphone-centric audiophile.
15" MacBook Pro w/TouchBar (2016)
2.7 GHz Quad-Core Intel Core i7
16 GB 2133 MHz LPDDR3
macOS 12.3.1
The MBP feeds a Thunderbolt 3 PCIe expansion chassis via a WireWorld USB 3.1 cable, positioned at the top of the systemās 3.1 bus hierarchy⦠I use the WireWorld USB3.1 cable instead of Thunderbolt 3/4 cable because of itās superior design architecture and performance as compared to a standard high-quality TB 3/4 cable⦠The expansion chassis hosts an ElFidelity AXF-107 āMagicianā Max Power Purification PCIe card, for power/noise filtering/conditioning/stabilization, and hosts a Sonnet Technologies four-port USB 3.1 card with four independent controllers, using only one output⦠the other three are screened with AudioQuest USB caps.
The USB 3.1 output from the Thunderbolt 3/4 PCIe chassis feeds and powers an iGalvanic isolation/filter/re-clocker, via a WireWorld USB3.0 cable⦠the iGalvanic feeds my TEAC DAC via a WireWorld USB2.0 cableā¦
The entire system architecture resides on, and star-grounded on, itās own power āislandā, being quad-filtered and augmented by an ADD-Power EAU2 harmonic resonator on the mains power, for extreme noise reduction. The power cables to the DAC and my HPA are WireWorldā¦
I use USB 3.x cables because the signaling-lines are separated from the data-lines in the cable architecture. (no adapters)⦠The USB2.0 cable is a very short lead to the DAC.
Audirvana Studio 1.12.2 is configured with SoX enabled for modulation of PCM to DSD128 being fed by 112DBās āRedline Monitorā HTRF audio-units pluginā¦
My library HDD lives at the top of the hierarchy of the systemās USB3.0 bus architecture⦠I find that separating the HDD USB3.0 data input feed from the USB3.1 data output feed to the PCIe expansion chassis, provides an audible improvement in sound-quality, most likely due to noise/jitter reduction from various operational interference.
I take great care to remove electro-mechanical interference and RF and EMF interference through a diligent and conscientious approach to noise mitigation/suppression. My cable internet feed passes through a Jensen galvanic isolatorā¦
This works for me in my unique personal system environmentā¦
[/quote]
