Big text, but fast doing it…
Start fresh Audirvana by deleting those files…
If you have Playlists that are important export them first to desktop and save them in a folder… when Audirvana is reset, you can re-import them back in one shot. sadly to this day, the folders they were in if so, are not back, you have to do them again…
Before doing this, maybe you should not connect after deleting those files to Roon, Tidal or others… Install Audirvana alone with your database… if working, log to Roon or else after.
Starting for new Audirvana:
Close Audirvana
Trash All the files in that folder (that is your database of music, back it up! or not)
Go to User… Home Folder… Library… Cookies…
Trash com.audirvana.Audirvana-Plus.binarycookies
trash com.audirvana.Audirvana-Plus.plist and com.audirvana.Audirvana.plist in that folder
(those are A+ software preferences)
Go to User… Home Folder… Library… Caches… com.audirvana.Audirvana-Plus
trash the files in that folder
Restart MAC.
This will reset pretty much Audirvana like new. You will need you serial number.
Open Audirvana, enter serial, choose a library folder at first it will sync in top middle of main window… LET IT GO, even better don’t try to adjust windows or edit files, even playing music while it is not finished… you’ll see the progress bar going… Could be long the first time depending on how large your library is, and MAC is fast or not… go to sleep if it is too long ![:slight_smile: :slight_smile:](https://community.audirvana.com/images/emoji/apple/slight_smile.png?v=9)
Then when finished, shut down Audirvana, yes close it before playing a song… That way you will have your database from stratch saved without crashing. Then copy the .sqlite file to somewhere else as a backup, then open Audirvana, and try to play a song.
Stop the music, go to preferences menu and do the 3 steps of maintenance of database. Close Audirvana after the third one… recopy the .sqlite as for the latest backup of clean database.
Open Audirvana and edit the tags that are not like you want ![:slight_smile: :slight_smile:](https://community.audirvana.com/images/emoji/apple/slight_smile.png?v=9)
You got brand new interface and new sound…
Go to Audirvana menu and select preferences… look at them all.
Click on speaker icon in the bottom right main window… select your DAC,
then the arrow right of it and look at all the preferences there too…
Click library icon on top left, click cover if you prefer covers over tracks mode… cmd + or - will make them bigger or smaller… click a cover to see it songs… do cmd i to see the info panel of that album, click a song and select them all with cmd A and do cmd i to see all their infos to be edited by you if needed… when you see the tracks you can add menus the the fields you see by right click menu bar and add any menu there you want (same for track view mode), you can also stretch each menu like long you want them or remove some you don’t need, depending how big your screen. Double click a song and listen, be happy ![:slight_smile: :slight_smile:](https://community.audirvana.com/images/emoji/apple/slight_smile.png?v=9)
