Hello Damien3,
Yes, this is exactly what i mean.
Here are the settings of Audirvana: (if it is helpful fpr you)
Audirvana 3.5.39
Per track: OFF
SoX to DSD64 with filter type A 7th order
Phase = 73
Replay Gain: by album
SW volume control: ON
AUTO: D:\Musik
Library database path: C:\Users\kdros\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 7052MB
Local Audio Engine:ASIO 2 driver version 0
Mytek USB Audio
Model UID:Mytek USB Audio
UID:Mytek USB Audio
Mytek USB Audio Manufacturer:
Model UID:Mytek USB Audio UID:Mytek USB Audio
0 available sample rates up to 0Hz
Simple stereo device: No
0 output streams:
Number of active channels: 2
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #1: Mytek USB Audio Manufacturer: Model UID: Mytek USB Audio UID: Mytek USB Audio
Thank you for your efforts.
