Hi everyone,
I’ve been using Audirvana for a few months now, and I’m impressed with the sound quality it delivers. However, I feel like there’s still room to fine-tune my setup for even better performance. I was hoping to get some advice from this knowledgeable community.
Here’s my current setup:
- Hardware:
- DAC: [Insert DAC model]
- Amp: [Insert amplifier model]
- Speakers/Headphones: [Insert model]
- PC/Mac: [Insert specs, e.g., MacBook Pro 2021, Windows PC with i7, 16GB RAM, etc.]
- Software Configuration:
- Audirvana version: [Insert version]
- Streaming Services: [e.g., Tidal, Qobuz]
- File Types: [e.g., FLAC, DSD]
- Output Settings: [e.g., WASAPI, ASIO]
A few specific questions I have:
- Upsampling: Is enabling upsampling beneficial, and if so, what settings do you recommend for my setup?
- Audio Filters: Are there specific filters or EQ adjustments that improve clarity or bass response without compromising the natural sound?
- Latency and Buffer Size: What’s an optimal balance for minimizing dropouts while maintaining high fidelity?
- Connection Type: Does switching from USB to a network connection (via DLNA/UPnP) noticeably improve sound quality?
- Other Tweaks: Are there any hidden features or lesser-known settings in Audirvana that could elevate the listening experience?
I also checked this: https://community.audirvana.com/t/does-audirvana-support-multi-output-device-on-a-mac/tableau
I’m open to any tips or suggestions, even if they involve adjustments to my hardware or streaming preferences. I’d love to hear about what has worked for you and how I might apply similar techniques to my system.
Thanks in advance for your help!
