I’ve suddenly started getting a loud noise when tracks start using Waves Abbey Road studio Plugin. Ok with other plugins.
Debug:
Audirvana Origin 2.5.2 (20502)
macOS 10.15.7 with 16GB physical RAM
Connected account of : Keith Forbes
AU plugin #0: Music Effect - Waves Abbey Road Studio 3 (s) ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX to DSD64 with filter type B 7th order
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by album
Sync list: 2 folders
AUTO: /Volumes/Music/Music/1.Albums
AUTO: /Volumes/Music/Music/Mixes and Compilations
Library database path: /Users/4bs/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on fe80::1083:9ce0:36de:d905%en0 on port 51565
Max. memory for audio buffers: 4236MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
FiiO FiiO BTA30 PRO
Model UID:FiiO BTA30 PRO:2972:0047
UID:AppleUSBAudioEngine:FiiO:FiiO BTA30 PRO:14120000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:iFi (by AMR) HD USB Audio
Manufacturer: iFi (by AMR)
Model name: iFi (by AMR) HD USB Audio
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0002:1
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
ID 0x2a
Audio buffer frame size : 116 to 4096 frames
Max volume alert: Disabled
Stream ID 0x2b 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Device #0: ID 0x43 Built-in Output
Model UID: AppleHDA:82
Device #1: ID 0x2a iFi (by AMR) HD USB Audio
