Lyrics in Audirvana
I think that displaying lyrics is a great missing feature in Audirvana. Any concrete plans to develop this?
Thanks,
Bernardo
I would like to second Bernardo.
If may go further, I would suggest the lyrics could be displayed when in “reduced” mode, the one with the album cover.
In that mode, an arrow could allow to slide out to the right a panel displaying lyrics, if any present in the file of the currently played track.
Yeah. Lyrics would be awesome!
I agree. Would be especially great with the mini-player view, with the lyrics floating above the album art.
Tout a fait d’accord avec cette requĂȘte, j’ai beaucoup de paroles taguĂ©es avec MP3tag sur le tag UNSYNCEDLYRICS, ce serait vraiment un plus de pouvoir y accĂ©der dans Audirvana sans avoir Ă  passer par Genius ou autre
 :+1:
Yes sure! It would be a fundamental improvement. Possibly also interfacing with QUICKLYRIC or similar app, maybe even on smartphones.
It would be nice feature if the interface gets lyrics integration.
Well, yeah
 Don’t you?
Dear Audivarna’s Developers, I think now is the perfect time to implement lyrics support/syncing in Audirvana as in Roon/Tidal softwares!
What do you think guys?
I miss lyrics in Audirvana as well. Thatswhy IÂŽm considering roon. Only problem is the price.
JRiver supports lyrics too
There are a few some other players that display lyrics, but I won’t name them on the site of Audirvana.
Amazon
Yes, lyrics would be nice BUT I still place Shuffle by Album at the top of my list of features needed.
Ambitious you are :wink:
The sorting within Audirvāna makes it a must. Too many times do I have to listen to all of my Puccini, etc. or Reference Recordings, etc. albums in my playlists. If Foobar can do it I am sure Audirvāna can bring their own take on it as well.
Every music player imaginable has support for reading the LYRICS tag. So it doesn’t need to be fancy, just add support for viewing lyrics on the tag editor screen.
Use Lyrics X, it’s great.
Hello max2bw
Please can you explain how you set LyricsX to work with Audirvana Studio ?
Thanks!
Edit: Right, you were talking about Audirvana Studio. Unfortunately I’m using AV 3.5, so if it doesn’t work with AV studio (which I’m assuming it doesn’t) you should maybe open an issue on GitHub. With more people asking it’s probably more likely to get implemented.
EDIT 02/23: 1.6.3 (latest) should support AV Studio!
Sure, however it’s only available for Mac. Though I’m sure Windows users can utilize similar apps.
Note: I’m using the fixed version that’s a little different than the latest stable release (Releases · ddddxxx/LyricsX · GitHub).
Well, it just fixes a bug, where the App has to be restarted in order to detect the lyrics for every single new song.
Latest (fixed) release (as of 12/2022) with all sources:
https://github.com/ddddxxx/LyricsX/files/9990783/LyricsX.app.zip
Just download the file and go to settings for setting different font sizes, etc.
If the app detects the playing song (it should), or if you set lyrics for a track, it’s automatically saved for that specific song (all lyrics are saved in a "Music“ sub-folder).
