I use Audirvana Origin on a Windows machine. I noticed that it is not possible (correct me if I am wrong) to manually type values for numerical settings which use a slider. The screenshots below are just a few, but this is the case with all these ‘slider’ settings. In the example below I want to set the number to 8000, but it is impossible to do so with the mouse+slider (because it is to crude). It would be nice to have the possibility (as in most Windows programs) to (double) click on the number and type it in/adjust it manually to fine tune it to the exact value I want. Normally (in Windows) focused sliders can be fine-adjusted with the arrow keys as well. This also does not seem possible in Audirvana because the slider controls do not get focus when clicked with a mouse.
Hi Guys. Sorry only half right. The RAM usage can only be changed by slider (didn’t check your first screen shot), however the settings under Upsampling can be changed manually.
Thanks for trying! If I double click (in Windows) the numerical values under Upsampling I can see the background color changing (like it is selected for editing), but I can not type anything in it. So in Windows it still does not seem to work.
Wow! Thanks @DGrigorescu. That works! I had to remove my glasses and use a magnifying glass to actually see the focus frame around the fields. At first it seemed that the sliders where not getting focus, but after closer inspection I could see that it worked. Thanks again. Now I know it I can’t unsee it anymore . Until now I tried clicking with the mouse on it, but that does not give focus.
I will mark your answer as solution, because this is good enough for me
Yup, so frustrating on a Mac when you have 128 GB, slider moves +/- a 1000 mb with just a slight roll of the finger on the touchpad. In the grand scheme of things really not an issue, but for those for whom precise is a life long ambition…so frustrating.
The volume slider is what annoys me the most. My vintage preamplifier has no remote and my DAC has no digital volume control. Sometimes I rely on Audirvana to adjust volume instead of walking up to the rig to adjust. Can be quite annoying clicking through .1dB decrements or clicking and suddenly jumping 10dB. Wish I could just type in the exact dB i want.
