Here’s a video detailing the issue
After 3 minutes, Audirvana consumes so much RAM (>21GB) that music starts to crackle.
Debug info:
Audirvana Origin 2.5.1 (20501)
macOS Version 14.0 (Build 23A344) with 32GB physical RAM
Replay Gain: by album
AUTO: /Volumes/NAS/Music
Library database path: /Users/user/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50704
Max. memory for audio buffers: 4096MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Topping DX7 Pro
Model UID:DX7 Pro:152A:8750
UID:AppleUSBAudioEngine:Topping:DX7 Pro:14200000:1
Active Sample Rate: 96kHz
Selected device:DX7 Pro
Manufacturer: Topping
Model name: Topping DX7 Pro
Model UID: DX7 Pro:152A:8750
UID: AppleUSBAudioEngine:Topping:DX7 Pro:14200000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x66
Max volume alert: Disabled
Stream ID 0x67 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x66 DX7 Pro
Device #1: ID 0x6c MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
