KenDB
June 28, 2021, 2:40pm
#1
Mini-Player controls are unresponsive using iPad mini 3 in landscape mode. Progression bar and volume control do not scale to fit on screen.
Same on iPad Pro in landscape. The button like pause, next/previous track…not working.
In portrait it works…
organm
July 10, 2021, 5:24am
#3
Yep, same for me. I-pad Pro Landscape Orientation , Mini-Player basically useless. Agree, works in Portrait Orientation.
@Antoine is this issue taken into account ?
Hello @organm , @Patatorz this issue has been reported at the launch of the Remote on iOS, we are working on it as we needed to launch the Android Remote before taking in account the bug on the landscape mode of iPad.
gryffe
November 12, 2021, 7:34pm
#6
@Antoine has this been sorted yet? I cannot get pause to work in portrait or landscape on my iPad.
I also posted here with more detail but nobody has replied
I can’t get the pause button to work on my iPad when AS is running on my Macbook. It works fine on my Android remote if AS is running on Windows PC. I uninstalled the iOS remote and reinstalled to make sure it’s the most up to date version, and my iPad is also on the most up to date version. Anybody else experiencing the same, or any ideas how to fix.
Thanks.
If it helps, I’ve just realised that it’s only a problem if playing through my hifi. The streamer I’m using is a Cambridge Audio 851N(although I suspect I could use any streamer and still have the issue) and cannot pause with that, but can pause if just playing through macbook speakers.
Edit - although I cannot pause when using with the hifi I can skip songs so it’s not totally unresponsive.
gryffe
November 13, 2021, 3:38pm
#7
@Damien or @Damien2 - looks like @antoine has not been online for a few days - can either of you assist with my problem with ios remote? Thanks.
