Audirvana Studio 2.2.3 (20203)
macOS Version 13.2 (Build 22D49) with 64GB physical RAM
r8brain to DSD256 with filter type B 7th order
Replay Gain: by track
AUTO: /Volumes/Music/FLAC
Library database path: /Users/morpheus/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49906
Max. memory for audio buffers: 64512MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
CA CA DacMagic 200M 2.0
Model UID:CA DacMagic 200M 2.0:22E8:DAC2
UID:AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:1100000:1
Active Sample Rate: 96kHz
Selected device:CA DacMagic 200M 2.0
Manufacturer: CA
Model name: CA DacMagic 200M 2.0
Model UID: CA DacMagic 200M 2.0:22E8:DAC2
UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:1100000:1
USB Vendor ID: 0x22e8
USB Product ID: 0xdac2
ID 0x33
MQA Decoder device
Stream ID 0x34 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 7
Device #0: ID 0x94 BenQ SW271
Manufacturer: BNQ
Model UID: 09D15F7F-0000-0000-211C-0104B53C2278
Model name: BNQ BenQ SW271
Device #1: ID 0x85 BenQ SW271
Manufacturer: BNQ
Model UID: 09D15F7F-0000-0000-211C-0104B53C2278_00000002
Device #2: ID 0x33 CA DacMagic 200M 2.0
Manufacturer: CA
Device #3: ID 0x77 CalDigit TS4 Audio - Rear
Manufacturer: CalDigit,Inc.
Model UID: CalDigit TS4 Audio - Rear:2188:6536
UID: AppleUSBAudioEngine:CalDigit,Inc.:CalDigit TS4 Audio - Rear:111400:1
USB Vendor ID: 0x2188
USB Product ID: 0x6536
Model name: CalDigit,Inc. CalDigit TS4 Audio - Rear
Device #4: ID 0x67 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #5: ID 0x3b krisp speaker
Manufacturer: Krisp
Model UID: KrispAudioDeviceSpeakerModelUID
Model name: Krisp krisp speaker
Device #6: ID 0x43 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 1
Device #0: Kitchen Display
Model name: Google Nest Hub
