Hello
I’m having an issue with the trial version of Audirvana not recognizing the ASIO driver of my Musical Fidelity MX-DAC. Also, as this is also a DSD128 dac, when selecting the WASAPI driver Audirvana does not recognize the DSD128 format. It only sees DSD64. When trying to play a DSD128 file it gets down converted to PCM. I have tried using Jriver and don,t have any of these issues. Jriver recognizes the ASIO driver as well all the DSD formats supported by the DAC. This seems to be a problem with the Audirvana software as Jriver sees the dac with no problem. Please help. Would lie to use Audrvana for Qobuz integration.
Thank You
Audirvana 3.5.43
Per track: OFF
Phase = 100
Max allowed volume: 19.5137
Replay Gain: by album
Sync list: 2 folders
AUTO: C:\Users\synek\Music
AUTO: C:\Users\synek\OneDrive\Desktop\test
Library database path: C:\Users\synek\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2588MB
Local Audio Engine:WASAPI
Musical Fidelity MX DAC ASIO Driver
Model UID:Musical Fidelity MX DAC ASIO Driver
Active Sample Rate: 192kHz
Speakers (Musical Fidelity MX DAC USB 2.0 Audio) Manufacturer:
Model UID:Speakers (Musical Fidelity MX DAC USB 2.0 Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b4b2c1c7-5ad2-4142-a6e9-7a644802a388}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Speakers (Musical Fidelity MX DAC USB 2.0 Audio) Manufacturer: Model UID: Speakers (Musical Fidelity MX DAC USB 2.0 Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b4b2c1c7-5ad2-4142-a6e9-7a644802a388}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speaker (Realtek® Audio) Manufacturer: Model UID: Speaker (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2f427fa8-e58e-4e01-b16e-69f1fd0c8780}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0Denon AVR-X2500H UID: uuid:cd51ddc7-671a-1164-0080-0005cdc931d6 Location: http://192.168.0.8:60006/upnp/desc/aios_device/aios_device.xml
