Situation: Playing local files without importing into the library is currently not possible (Audirvana Studio 2.5.2).
Issue: It takes 13 clicks (see below) to listen to local music in âad hocâ mode, being forced to abuse the library functionality, which was never optimized for this task.
Resolution: How this should work instead (urgent feature request): Drag a local folder onto Audirvana, pop-up should offer a choice of â1. Play Now; 2. Play Next; 3. Add to Play Queue; 4. Add to Playlistâ).
Current steps / current pain:
Click on Settings
Click on Local
Click on âAdd a folderâ
Navigate to folder (multiple clicks)
Click âOpenâ
Click on âLOCALâ (left hand pane)
Now, we are running into more interesting problems:
in âLocal > Folders Viewâ, it is not possible to select a folder to add to/as a playlist
7a. Have to click on a track
select all (Command A)
right-click âadd to play queueâ
press play
â
Once done listening, clean up time: Click on Settings
Click on LOCAL
Click on trashcan icon next to previously imported folder
Yep. You can drag and drop files from Finder (Mac) or File Explorer (Windows) on Audirvana to play them. You donât need to add them to the Audirvana library for that.
I added âFull disc accessâ for Audirvana Studio (macOS Sonoma).
Now I can select multiple files, right click, open with - Audirvana Studio.
However, this doesnât work for files on a network share. Nothing happens. Also, there is no drag & drop. If I take a local file and hover over different parts of the Audirvana Studio user interface, the cursor doesnât change to reflect a valid drop target. Randomly dropping the file on 20 different parts on the screen also doesnât work. Dropped on the Mini Player: Nothing happens.
Drag and drop them from the File Explorer (in Windows) or Finder (Mac) on an open playlist in Audirvana. On my system (Windows) that works and always has worked.
Thank you. I was missing the crucial step âcreate dummy playlist as a drag & drop targetâ.
I can confirm this works on my Mac, including with network files.
