Network amplifier gone
Hi there
Running AS in trial mode, only 7 days for free left and I still have a big issue!
As version 2.9.4.1.1 amplifier visible in output window, after shutting down pc and amp on stand by next dag startup and amplifier is gone.
Then I install version 2.9.5 and amplifier shows up again immidiately. And after shutting down, the next day amplifier also gone.
Next day installing version 2.9.4.1.1 again and surprise; amplifier present again.
Pretty tired :yawning_face: of installing different as version each day .
Which sounds like a issue in your home network.
So… If the USB connection playback is flawless and the computer is using DHCP and the Hegel is not on a static IP address, there seems there is an issue with your network configuration or device(s) or environment in which these devices operate, that precipitates the loss of synchronization… You cannot rule-out the amp as a potential point of incompatibility with the UPnP protocol in the newer version of Audirvāna. What does Hegel say about this behavior?
You must understand that many Audirvāna Studio users that are playing files via UPnP protocol in AS 2.9.5. do not have this behavior that you are experiencing…
Once again, please paste your debug information here when using AS 2.9.5…
Hi @Agoldnear
Indeed no other massages regarding this issue from other users.
Hi @Agoldnear
Audirvana Studio 2.9.5 (20906)
macOS 15.1.1 x86_64 with 8GB physical RAM
Connected account of : Peter van Veer
Local network access: allowed
	No plugin active
Sync list: 2 folders
AUTO: /Users/vantveer/Desktop
AUTO: /Users/vantveer/Documents/muziek
Sort and display order: en
Library database path: /Users/vantveer/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 458
Listening on on port 50193
TIDAL: Connected as PREMIUM
Font size: large
Language: English
My Music
Radios
Podcasts
Streaming
Use media keys: no
Use media keys for volume control: no
Use Apple Remote: no
Number of paired remotes: 1
Screen saver disabled: yes
Active method: UPnP
Selected Network interface: USB 10/100/1000 LAN
Wi-Fi
USB 10/100/1000 LAN
Preferred device: [UPnP] H90 093C2B Model UID:Hegel H90 UID:uuid:5f9ec1b3-ed59-1900-4530-cc9093093c2b
Selected device:H90 093C2B
Manufacturer: Hegel
Model name: H90
Model UID: Hegel H90
UID: uuid:5f9ec1b3-ed59-1900-4530-cc9093093c2b
UPnP device at http://192.168.2.57:8080/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-wavetunes:
:audio/x-ms-wma:*
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:05:36
CurrentURI: http://192.168.2.56:49152/audirvana/audio_f_14.wav
CurrentURIMetadata:
dc:titleThe Vision</dc:title>
dc:creatorVictor Wooten</dc:creator>
upnp:artistVictor Wooten</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/83797d9c/bbed/44e0/8fa7/2ac150752a1d/640x640.jpg</upnp:albumArtURI>
upnp:albumA Show of Hands 15</upnp:album>
upnp:originalTrackNumber5</upnp:originalTrackNumber>
nextURI: http://192.168.2.56:49152/audirvana/audio_f_15.wav
Words of Wisdom Victor Wooten Victor Wooten http://resources.tidal.com/images/83797d9c/bbed/44e0/8fa7/2ac150752a1d/640x640.jpg A Show of Hands 15 16 object.item.audioItem.musicTrack http://192.168.2.56:49152/audirvana/audio_f_15.wav
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Next,Previous
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:2 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 H90 093C2B Hegel http://www.hegel.com/ Stereo Audio Amplifier H90 http://www.hegel.com/ CC9093093C2B uuid:5f9ec1b3-ed59-1900-4530-cc9093093c2b 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.2.57
UPnP devices found : 1
Device #0: ID 0x0 : H90 093C2B
Manufacturer: Hegel
Model name: H90
Max. memory for audio buffers: 3600MB
Local Audio Engine: CoreAudio
Device #0: ID 0x69 MacBook Pro luidsprekers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Pro luidsprekers
Device #1: ID 0x49 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Do you have both the WiFi connection and the USB Ethernet connection active simultaneously?
Hi
If you mean in my MacBook Pro I say yes. If I close one down my remote AS does not work ( installed on my I phone)
The remote will connect to your router via WiFi… The MacBook does not need WiFi enabled for communication with the Remote.
Okay I shut wifi down on my laptop. And will post any fortcoming issues.
Are you using WiFi anywhere in the network configuration to the amp?
Take a look at this thread…
Thx for your help @Agoldnear
I do not use wifi
Is your Teams App in the login items of your Mac ?
What if you don’t change the install of Audirvana, but switch of the Hegel amplifier and turn it on again. Does the amplifier appear?
dear @RunHomeSlow
I do not have TEAMS running anymore on my device but can not get rid of this since do not know what to do to get rid of this.
Dear @jmtennapel
I did this morning and with WiFi turned off as @Agoldnear recommended but network does not show up in Audirvana.
Here is debug file.
Local network access: forbidden
	No plugin active
Tracks with no MBID: 469
Listening on on port 49193
Font size: large
Language: English
My Music
Radios
Podcasts
Streaming
Use media keys: no
Exclusive access: ON
Integer mode: ON
[UPnP] H90 093C2B
Model UID:Hegel H90
Selected device:MacBook Pro luidsprekers
Model UID: Speaker
ID 0x69
Stream ID 0x6a 2 channels starting at 1
4 virtual formats:
4 physical formats
Model UID: Speaker
USB 10/100/1000 LAN
It could be the ā€˜local network’ bug on MacOS Sequoia.
Go to the apple logo in the top left corner > system settings > Privacy and safety (or something like that, I have a Dutch MacOS interface). In the pane on the right hand side, scroll down to ā€˜Local network’, click it and see if Audirvana has permission for the local network access.
@jmtennapel
just checked settings are okay
how is this possible?
I did not change anything and here it is again. but network 10/100/1000 LAN still not visible. very odd, but music is here again, lets wait for how long.
It is probably a network configuration issue. But then you need to lay out precisely what your network looks like, including switches, LAN adapters and whatever you use more to be able to find out what could be the cause. I’m not a network expert, so you probably need someone to have a look.
